It is currently Fri Mar 29, 2024 6:12 am
 Post subject: Volvo 240 Wagon Build Thread
PostPosted: Sat May 11, 2019 11:29 pm
Hey, figured I'd start a build thread and track my progress.
Located in Lethbridge Alberta.
Overall, the car is pretty decent shape.
Plan for the car is to just get it to be a nice clean daily driver cruiser. I wanted a cruising car while I rebuild an engine for my mustang. Once that car is back on the road, then maybe I'll do more heavy modification on this car.
ImageIMG_9604 by Richard Brown, on Flickr
ImageIMG_9606 by Richard Brown, on Flickr
ImageIMG_9614 by Richard Brown, on Flickr
ImageIMG_9628 by Richard Brown, on Flickr
ImageIMG_9652 by Richard Brown, on Flickr
Done so far:
-New taillights (fixed broken lights)
-Headlight bulbs (fixed highbeam issue)
-Acquired and installed rear driver trim
-Air filter replacement
-Acquired and installed license plate lights (not working, wiring needs repair)
To do list:
-Tune up. I know the injectors and lifters are noisy, but seems a bit excessive? Trying to clean the system out, change oil and then progress deeper.
-Replace hatch. Only real rust on the car, have replacement hatch from older 240. Just need to paint and install.
-Rear gate wiring. No wiper, defrost, unlock, license plate lights. Have passenger IPD harness, planning on making drivers side. Doing at same time as hatch replacement.
-Reverse lights. Trans sensor needs replacement, have part.
-Seal headlights. Lens pulls out?
-1 door door not central un/locking
-Dome light and chime. Door sensor.
-Fix heated seats
-Recharge AC
-Timing Belt (have parts)
-Rear hatch panel repair
-Various interior clip replacement
-Polish/paint correction
-Clean/paint parts
-Front lip repair
-Wheels (WTB)
-Cruise control lever. Previous owner replaced lever with cheaper level w/out cruise, have cruise lever hanging to still allow use. Want to replace with correct lever.
-Odometer fix
WTB:
-Summer wheels & tires. Like current wheels, but not in great shape and have winters. Would like another set.
-Hatch shocks
-Odometer gears
-Cool parts?
 Post subject: Re: Volvo 240 Wagon Build Thread
PostPosted: Sun May 12, 2019 4:23 pm
Welcome to the board. Funny, I just picked up a 245 myself. Not in great shape, but give me a minute. Sorry for taking so long to get you registered - I was having issues with the back-end control.
I guess Matt must have sorted you out. Anyway - there are a few of us on the board from Lethbridge.
PostPosted: Mon May 13, 2019 9:54 am
Yeah, we should be thinking of renaming the board (he says jokingly) as there are approximately 1 users from Calgary who ever comment.
PostPosted: Sun Jun 23, 2019 6:53 pm
-New front speakers
-Door sensors
-LED dome lights
-Oil change
-Seafoam
-Fixed reverse light (didn't replace sensor, was unplugged - wiring needs future attention)
-Recharged AC
-Bought and replaced some interior clips
-New license plate bracket (modified to 2 bolt)
-Painted brake calibers bronze
-New wheels
ImageIMG_1909 by Richard Brown, on Flickr
ImageIMG_1910 by Richard Brown, on Flickr
ImageIMG_1913 by Richard Brown, on Flickr
ImageIMG_1916 by Richard Brown, on Flickr
ImageIMG_1926 by Richard Brown, on Flickr
ImageIMG_1929 by Richard Brown, on Flickr
ImageIMG_1934 by Richard Brown, on Flickr
ImageIMG_1937 by Richard Brown, on Flickr
ImageIMG_1941 by Richard Brown, on Flickr
ImageIMG_1947 by Richard Brown, on Flickr
ImageIMG_1953 by Richard Brown, on Flickr
ImageIMG_1968 by Richard Brown, on Flickr
PostPosted: Mon Jun 24, 2019 12:24 pm
Lookin' good with the Classic wheels.
PostPosted: Sun Jun 30, 2019 8:16 am
Welcome to the site, my apologies for taking so long to post. I watched this car on Kijiji the whole time it was up, glad it stayed local with someone willing to put it right. Very nice work so far, looking forward to your progress.
PostPosted: Mon Sep 02, 2019 7:40 pm
Been very busy at work the last couple months, but found some time to work on the Volvo and continue to strip my mustang parts car.
A few more updates:
- E code headlights, more of a project that I expected... First they came broken from fcpeuro, had a awful experience with shipping and didn't want to send them back for replacements. Repaired them. They also don't work with NA corner lights. Had to make a custom bracket from the corner lights and do significant trimming to the headlights. Also don't use the same bulbs? Had to modify the dust boot to fit with my bulbs/connectors. Still require alignment.
- Amber reflector removal
- Fuel filter - damaged a line, had trim and put barb fitting back in. That was a real treat...
- Flame trap
- Air box - removed heater tube and cut it open for better cold air flow.
- Front brakes - rotor and pads. No more brake vibration.
- Front wheel balance - no more vibration on highway
- Blue lug nuts
- Hella Horns - Doesn't sound like a boat anymore
- Engine bay detail and paint
Before:
ImageIMG_20190817_154449 by Richard Brown, on Flickr
Stock lights
ImageIMG_20190817_155915 by Richard Brown, on Flickr
E-code - tabs don't work with NA corners. Can to trim them off and make my own bracket for corners.
ImageIMG_20190817_160038 by Richard Brown, on Flickr
My custom bracket. A bit roadkill, but used what I had. Worked well.
ImageIMG_20190817_175636 by Richard Brown, on Flickr
ImageIMG_20190817_175839 by Richard Brown, on Flickr
Before:
ImageIMG_20190818_134825 by Richard Brown, on Flickr
ImageIMG_20190818_134831 by Richard Brown, on Flickr
After:
ImageIMG_20190818_144728 by Richard Brown, on Flickr
ImageIMG_20190818_144744 by Richard Brown, on Flickr
Brakes:
Bronze is fancy rust paint. :p
ImageIMG_20190819_113244 by Richard Brown, on Flickr
Hellahorn - not so boaty... Well still a boat, but doesn't have a boat horn anymore.
ImageIMG_20190824_125817 by Richard Brown, on Flickr
ImageIMG_20190824_125916 by Richard Brown, on Flickr
As it sits now! Really happy with how it drives. Would like to improve the starting, it always starts but randomly a little rough? Just going to continue to clean and do preventive maintenance.
Once the mustang is back on the road, then I'd like to do some bigger modifications. Right now this shares daily drive duties with my truck.
ImageIMG_3964 by Richard Brown, on Flickr
ImageIMG_3965 by Richard Brown, on Flickr
ImageIMG_3970 by Richard Brown, on Flickr
ImageIMG_3971 by Richard Brown, on Flickr
ImageIMG_3974 by Richard Brown, on Flickr
ImageIMG_3976 by Richard Brown, on Flickr
ImageIMG_3980 by Richard Brown, on Flickr
ImageIMG_3992 by Richard Brown, on Flickr
PostPosted: Tue Sep 03, 2019 7:47 am
Yeah, the US headlights use ... US bulbs. 9004/9007 are garbage that are DOT specified bulbs that are ONLY used in North America, as far as I know. Getting E-code headlights in your car isn't as simple as just buying the lights, as you've discovered: They require so much more.
Car's looking good, though.
PostPosted: Tue Sep 03, 2019 12:02 pm
That’s looking so much better, kudos on the photos as well. I’ve looked at those e-codes from FCP before and they show the corners and trim pieces included? Also shows the H4 connectors and bulbs as part of the package, was that part of the shipping disaster?
For the rough idle try cleaning the IAC valve. check for codes it could be the coolant temp sensor as well, although that should light the CEL.
PostPosted: Tue Sep 03, 2019 7:27 pm
Yeah I under estimated the install of lights... Assumed they would be same...
FCP has the kits, but at the time they were selling the headlights separately. I must have got the last set.
It doesn't seem to idle bad. It just cranks longer than normal, and rpms very slowly climb. Then it seems normal again. Seems to do it most often when I drive it to work and it sits in the sun? But not always.
PostPosted: Fri Sep 06, 2019 10:38 am
The cranking longer than normal I would check the FPR, the main pump check valve, and the intank pump.
PostPosted: Mon Dec 09, 2019 8:01 pm
Not much for updates. Have been working on the Mustang - got a large shipment of parts in for it, currently working on some porting/cleanup of the top end.
Anyways, a couple photoshoots of the Volvo I did recently.
ImageIMG_4243 by Richard Brown, on Flickr
ImageIMG_4251 by Richard Brown, on Flickr
ImageIMG_4262 by Richard Brown, on Flickr
ImageIMG_4265 by Richard Brown, on Flickr
ImageIMG_4269 by Richard Brown, on Flickr
ImageIMG_4271 by Richard Brown, on Flickr
ImageIMG_4276 by Richard Brown, on Flickr
ImageIMG_4281 by Richard Brown, on Flickr
ImageIMG_4291 by Richard Brown, on Flickr
ImageIMG_4303 by Richard Brown, on Flickr
ImageIMG_4308 by Richard Brown, on Flickr
ImageIMG_4314 by Richard Brown, on Flickr
ImageIMG_4318 by Richard Brown, on Flickr
ImageIMG_4335 by Richard Brown, on Flickr
ImageIMG_4337 by Richard Brown, on Flickr
PostPosted: Tue Dec 10, 2019 8:54 am
Great shots as always!
PostPosted: Fri Dec 13, 2019 9:18 am
Agreed, great pics. ThAnks for sharing.
PostPosted: Sat Dec 21, 2019 5:49 pm
Merry Christmas! This is my vision for the car. Lowered, Ford fan wheels, and a roof rack complete with xmas tree
Imagevolvowhitebg by Richard Brown, on Flickr
