 Post subject: Boxing and Extending 240 Lower Control Arms
PostPosted: Tue Jul 07, 2015 8:35 pm
The lower control arms on 240's are meant to fold up in the event of a front end collision which means that they are pretty flexible and it seems that everyone boxes them to increase the steering sharpness. My car also had no ability to have camber - so I decided to just lengthen the ball joint mounting point as this is the cheapest way to get a lot of camber. With my recent foray into the world of autocross, I either lengthened my LCA's or buy new front tires a couple of times a season (yes, it was that bad).
After chatting with a few people about this, the magic number seemed to be 40 mm. So with this as the basic design, on I went with the fabrication.
First up, build an extension piece to TIG weld onto the front of the existing LCA. This required some metal origami in my press - getting it perfect is a matter of patience, practice and measuring twice. The flange (short return at the base of the bracket) was considerably longer, I then cut it to match the width of the existing. This made fabrication easier.
I then mocked up a ball joint to reference the holes and move them the required amount out. Drilled the holes and created a stud for the rear ball joint mount. Then I cut boxing plates from 16 gauge steel and welded them on. It looks like this when done. Don't forget to give yourself a generous hole to bolt on the rear of the ball joint bracket.
For the front ball joint mounts - you need to cut the boxing plate back a little to get full nut access.
Send the finished product out for powder coat and they're done.
This moved my suspension from zero camber to -3.3 degrees. This is as little as I can get, so the 40 mm is probably a little too much. I've got the original LCA's and may fix this little issue to get around -2 degrees as this may be a little too much camber.
I can tell you that the front end grip at this angle is very good. Only tire temps will tell and we're racing this weekend. Wish me luck.
Oh, and I changed out the tie end rods to a new set that I cut and lengthened...don't try that at home with a little buzz box - that's a job for TIG welding.
 Post subject: Re: Boxing and Extending 240 Lower Control Arms
PostPosted: Tue Jul 07, 2015 9:45 pm
Wow! That's a lotta camber. How is it driving around town? Looks awesome!
PostPosted: Wed Jul 08, 2015 8:37 am
It is fine driving around - it tracks straight and doesn't feel different at normal speeds. When pushed it's a completely different animal. We'll know better on Sunday when I push it harder, but over my little local "race track" (the roundabouts on the way to Paradise Canyon) - the tendency for the car to understeer is gone. It finally has front end grip. Now, it may be even better at -2.5 - but with the body roll caused by the lack of rear bar, I suspect I might just be fine. I really wish I could tune it, but my towers just won't allow tuning as one side is more upright than the other and I'm not going to build a frame jig to reference that and pull it all out of the car. Though as I think about it, it wouldn't be that hard to fix...so when it goes back in to the garage after the 122 is done, it's on the upgrade list. I do have a frame jig.
Anyway - it felt great (for a 240). We'll see what the tire temps tell us - thankfully Matt's running in a different category this Sunday, so he can be waiting for me in the pits with the tire temp gauge.
PostPosted: Wed Jul 08, 2015 11:01 am
Uhhh...there will be others there too... :D
PostPosted: Wed Jul 08, 2015 12:20 pm
I figured you'd be taking pictures or video of our efforts :lol: .
PostPosted: Wed Jul 08, 2015 1:24 pm
Interesting. I'll be very interested if the increase in front track width increase oversteer as well? I really wonder if you're gonna need at least some rear bar now to compensate for all the extra front end grip.
The Smurf had assymetric front towers too. Never could get a proper alignment. And yes, I'm sure Dale or I can get tire temps for you.
PostPosted: Thu Jul 09, 2015 8:12 am
I've said it many times but perhaps not in type...when Matt and I modified the upper mounts in the 122 we ended up with way more camber than we anticipated. Even with that amount of camber...as seen here...
Image[/URL]
tire wear didn't seem unusual and the car drove down the road relatively straight. It would get a little twitchy at higher speeds but it literally pulled itself around corners.
PostPosted: Thu Jul 09, 2015 9:07 am
Wait - you're coming to the AutoX! =D> =D> =D> We'll have a full crew - so stoked. Don't forget that I also have a wider rear track. Hasn't felt tail happy at all - but we'll see Sunday.
PostPosted: Thu Jul 09, 2015 9:10 am
Image[/URL]
Still one of the best car days of my life so far. Oh and it's hard to believe that I was ever that fat...we should crop me out of that picture.
Seriously, given my outside tire wear, a little inside tire wear would make things even. These are 5 year old tires anyway, so if I burn them this year, I'm not sad.
