It is currently Tue Apr 23, 2024 1:31 pm
 Post subject: cast aluminum finned valve covers for B18 - B20
PostPosted: Sat Feb 16, 2013 7:23 pm
I went searching and found a restoration company in California that does carry the cast aluminum valve cover but it's a little over $200. It's URL is http://www.classicvolvorestoration.com/ ... t_id=41631
They carry a lot of other interesting parts also to restore a PV544 and have PDF downloads for instructions for restoring. It's owned by an airline pilot.
Another place I found that carries an amazing amount of parts is http://www.thepartsbin.com/catalog/part ... vtype=link. Some parts they don't have listed but I found them anyway (ie: brake wheel cylinders by going to "Search by auto part name" and there they were.)
Still not too sure about a windshield tho for 544. This company carries a couple but whether they will ship up here I'm not certain.
On a totally dissimilar note I had some elecrtical work done on my 740 diesel and the fellow even pulled out the restrictive cone in the air inlet to the air filter and then drilled about 4 2"holes in the air filter box also. Did it ever make a difference, not hot rod but you can sure notice it in the performance and quicker revs. it will even continue to accelerate up our back hill. I used to have to rev to 4500 in second and even then it would start to slow down after shifting. No more, it continues to accelerate now, not great but still better and gas mileage has improved also. Neat. I want to try taking the resonator off the back now (muffler already gone) and see if that helps a little more.
 Post subject: Re: cast aluminum finned valve covers for B18 - B20
PostPosted: Sun Mar 10, 2013 9:45 pm
That's what they usually go for...IPD has gone in and out of stock of them this past year.
PostPosted: Sun Mar 24, 2013 9:23 pm
I phoned IPD and they said they lost their supplier and are looking for someone else but could take a year or two but these guys in California have them in red or black accent paint which wouldn't be hard to change anyway.
