It is currently Thu Apr 25, 2024 12:57 am
 Post subject: 240 Lengthened Front Lower Control Arms
PostPosted: Mon Jul 27, 2015 8:36 am
Hello All,
Yup, I'm going to sell this set of LCA's that I just built. I thought I'd drop them in here before dealing with the gang over at TBrix.
The extensions are at full material thickness and TIG welded with 100% penetration. These were built on brand new LCA's and were extended 40 mm and get 3 degrees of negative camber for my car. Professionally powder coated inside and out for long term durability. Boxed with 16 ga steel - fully welded perimeter.
Asking $250 for the set.
On the car.
I had them on the car for 150 km - the reason for selling is that with this much camber on my set-up, I was loosing too much front brake. I've also got a lot more front brake than you lot. These would be perfect for people running R-comp tires in either autocross or road racing. I built another set that allows me a degree less camber and I've got front brakes again. I was also terrified of running this much camber in the winter.
PM if you're interested.
