It is currently Thu Oct 31, 2024 4:54 pm
 Post subject: FS Walbro 255lph tank pumps
PostPosted: Tue Jun 06, 2006 9:34 pm
Grime Killer!
Walbro PN 12-915 255Lph intank fuel pumps, easy swap for any RWD Volvo and eliminates inline main pump. Have 5 units left, New In Box. Cost 169.00 each + GST :D
PostPosted: Tue Jun 06, 2006 9:56 pm
Ugh...that would solve some fuel issues, huh Matt?
PostPosted: Tue Jun 06, 2006 10:05 pm
Grime Killer!
whos car has the fuel issue Dale? I thought Dupuis had one of these in his 244?
PostPosted: Tue Jun 06, 2006 10:21 pm
I need to get fuel from the tank to the injectors in the 122. At this point we've got a 240 bung welded in with the 240 pick-up tube and return tube and 240 in-tank pump installed. We were going to work out external pump stuff shortly. How big is the Walbro compared to the Volvo in-tank pump? We had to shorten the pick-up tube substantially to get it in there...
PostPosted: Tue Jun 06, 2006 10:24 pm
I may take one, I'll let you know when i'm back in calgary
PostPosted: Tue Jun 06, 2006 10:30 pm
Grime Killer!
its about 50% longer than the volvo unit, I think I had to cut the feed hose in half when I did mine last summer. Of course you could make a spacer flange for the tank opening to allow more height... actually, I bet theres' a generic flange at mopac or on ebay for some nascar or rally car that wold bolt right on (or JB weld on) :?
PostPosted: Tue Jun 06, 2006 10:33 pm
The 122 tank sits in the floor (or, more like, is the floor) of the trunk. I'm going to build some sort of false floor to protect the fuel lines. I'd rather avoid making it taller, if I can....
PostPosted: Tue Jun 06, 2006 10:34 pm
Grime Killer!
oh yeah, I have 2 or 3 healthy B21FT main pumps that are clean and bagged. If you think they might work I'd gladly give them to you. :D
PostPosted: Tue Jun 06, 2006 10:38 pm
Thanks...I appreciate that. I might take you up on the offer. Eventually Matt will chime in to say yea or nay on the Walbro fitting. That route would be far more simple as it would eliminate an external pump and the need to find a spot to mount it to etc...
PostPosted: Wed Jun 07, 2006 7:08 am
If you'll remember, I suggested it waaaaay back when, Dale. You put the kaibosh on it because of money, and because we had a ton of K-jet pumps to choose from.
Of course it would work. We'll just have to shorten the pickup even more.
PostPosted: Wed Jun 07, 2006 7:19 am
Yeah...I know... I'm to a point now where the less fussing around we do, the quicker it'll be together... That was before Ian paid me for some tires & wheels too. Speaking of which... :P
Hey Brad...I think I'll take one...
PostPosted: Wed Jun 07, 2006 8:27 pm
Grime Killer!
let me know when you want it and we'll meet.
also sold one to Houston, 3 left now. :D
PostPosted: Wed Jun 07, 2006 8:32 pm
Grime Killer!
Dale, just thinking...you should go grab a pump/filter carrier out of one of those 700's at PYP. Then you have a bracket and harware/fuel fittings for your filter and check valve. That would make an easy install... Hose Headquarters sells 3/8 hose barbs with metric strait thread and copper washers that plumb right into a LH filter too.
PostPosted: Thu Jun 15, 2006 9:16 am
Hey Brad...Matt and I were discussing...I think we'll stay the course with the stuff we have. We've got a known good in-tank pump and about 8 external pumps, most of which were good. At this point there is no sense spending money if I really don't have to. There are still things I have to buy to get the car on the road. A fuel pump isn't one of them...
PostPosted: Thu Jun 15, 2006 10:54 pm
Grime Killer!
no problem, somebody else wants one and I only have yours' and houstons' left. I have 2 good k jets here for the asking if you need em in the future...
I was thinking, what about using 2 bosch main pumps in series with check valves and eliminate the tank unit altogether? Then you can use a stock d-jet float/outlet/return assembly...
