It is currently Thu Jan 17, 2019 10:03 am
 Post subject: 1800e Crossmember needed
PostPosted: Sun Jul 30, 2017 9:15 am
Hi, have a very soft spot on the bottom of the crossmember. Need a good replacement, or a quality welder to repair.
Any suggestions?
TIA
 Post subject: Re: 1800e Crossmember needed
PostPosted: Sun Jul 30, 2017 10:21 pm
Pictures? Where are you located?
PostPosted: Thu Aug 03, 2017 2:24 pm
Hi, thanks for asking. I'm Calgary based but not near the car right now. I'll get a picture next week. It's basically rusted through around the drain hole, about 3" x 10", right where you might put a floor jack. The vertical flanges up the front and back sides appear to be solid.
PostPosted: Sat Oct 21, 2017 12:45 pm
Hi, after some delay(life gets in the way) here’s a picture. Cutting out the rot and welding a new bottom on it seems to be the simplest cure.
Any suggestions, comments welcome.
Thanks.
