It is currently Fri Mar 20, 2026 12:03 pm
 Post subject: Engine stumbles on first acceleration after start-up only
PostPosted: Thu Oct 01, 2009 12:21 am
Hello all,
It's been a while since I've logged on here. My '95 940T has a peculiar problem. The first time I try to accelerate up to normal speed after a start up the engine stumbles/hesitates a fair bit. If I then step on the throttle it'll stumble/hesitate for another second or so and then it just takes right off accelerating quickly. Thereafter, the car will run and accelerate normally with no more stumbling or hesitation. It doesn't matter if the engine was hot or cold when I started it. Kinda weird. :-k
Anybody else have this happen ? Any ideas as to what's causing this problem ?
Thanks in advance.
Roger
 Post subject: Re: Engine stumbles on first acceleration after start-up only
PostPosted: Thu Oct 01, 2009 7:09 am
dirty/sticky idle control valve is my first guess
PostPosted: Thu Oct 01, 2009 4:37 pm
my car does the exact same thing except only if its cold, once it's warm it runs nice.
Doug
PostPosted: Thu Oct 01, 2009 5:15 pm
How does the cap/rotor and plugs look?
PostPosted: Thu Oct 01, 2009 6:56 pm
cap and rotor were replaced about a year and a half ago so im assuming that they're good and the plugs looked fine back in may when my car first started acting up and since then I havn't looked.
Doug
