It is currently Thu Mar 19, 2026 11:14 pm
Post a new topicPost a reply Page 2 of 2   [ 24 posts ]
 Post subject: Re: oops...i did it... again... too
PostPosted: Thu Jul 09, 2009 9:39 am
RaZ wrote:
Mr. Volvo does a horrible job 90% of the time. Sometimes outright LYING to their customers.
Maybe they just shimmed your starter for you? :) and had a bad ring gear laying around.
They told my friend with a 1980 240 DL Automatic that they were going to replace the transmission, they just added transmission oil and CHARGED HIM FOR A TRANSMISSION SWAP. I looked underneath, the bolts on transmission to bellhousing to block, none were touched, and transmission showed no signs of having been touched, at all, covered in road grime in same way as everything else under car.
We went back and got them to confess, got him a partial refund, that's not all we got, we got a nice threat of bodily harm if we were to come back.
Thanks Mr. Volvo, or should I say, Mr. Asshole.
:shock: huh? thats ridiculious! i've never had any bad luck with them and ive had them do quite a bit to my car! I've heard a few other things about them but so far so good for me! but i guess from now on im gonna check everything after I leave. the only reason I go there is because they are the cheapest and seem to do a good job.
Doug
PostPosted: Thu Jul 09, 2009 9:40 am
945_James wrote:
Without seeing the car, I'd echo what Craig said. More likely than not you will get to deal with a starter or wiring/switch fault on an $800 car. Probably not a big deal if it isn't badly beat down otherwise. I'd use an early starter...more durable and better on a DD or car with a questionable battery. For a car where saving the extra weight is an issue, not so much. For a daily beater, I say big starter all the way.
Thanks James, other than this initial glitch I am still positive that this car has lots of miles left in it. I think the price more reflects the cosmetic state of the car (crappy paint repair, busted tailight, but very little to no rust) as it runs and drives like a lower mileage car. All in all should be a decent DD for a teenager.
When you say big or early starter what exactly am I looking for? I was under the impression that Volvo used the same starter from the 60's to the end of the RWD era (source vlvworld.com). Also as you mentioned the battery, this car has the puniest battery I have ever seen in a 7xx car. It's an Interstate MT-47 rated at 590 CCA and 740 CA but is at least a couple of inches shy of filling the tray like the battery I bought recently for the blue beater. Having said that it looks to be in good condition testing 12.64 V static and 11.83 V with lights, fan, defroster etc. turned on.
PostPosted: Thu Jul 09, 2009 9:58 am
Those voltages are with the car off, and not having run for at least an hour I hope!
PostPosted: Thu Jul 09, 2009 10:05 am
yes and yes (stone cold actually). Why, what were you thinking??
PostPosted: Thu Jul 09, 2009 10:16 am
Good. just that it would be bad if that was while the car was running!
PostPosted: Thu Jul 09, 2009 3:28 pm
measure the voltage at battery, then measure voltage at starter. what is the drop? with car off, sure.
if there is a significant drop, you may have a problem.
PostPosted: Thu Jul 09, 2009 5:40 pm
OK test results as follows (while cranking): +'ve post on battery to +'ve lead on starter was 0.11V; -'ve post on battery to ground on starter case was 0.18V. From what I have been reading anything below 0.2V is good so this sounds normal? All of the connections look clean and tight, starter bolts look snug, basically everything looks and test's OK.
So everything looks fine and now the starter is turning over and sounds normal?? Now I don't feel so bad for not noticing it when we test drove the car but it was definitely sounding noisy after we picked it up and the next day when we brought it home??
PostPosted: Thu Jul 09, 2009 9:00 pm
could just be a sticky ignition switch like was mentioned before, sometimes they cause the starter to stay on, just wiggle the key a lil, it should stop :)
:mrgreen:
PostPosted: Fri Jul 10, 2009 10:05 am
:mrgreen:
When it was making noise it was a growling sound as it was cranking, once it fired and I released the key it was fine? It has never sounded like it wasn't disengaging. Like I said it's fine for now so I'm not sure what to think.
When starters get a flat spot where they stick in one spot and need a rap to get moving, do they ever start out growling when they hit that spot until it's worn enough to stick??
