It is currently Mon May 04, 2026 2:10 am
Post a new topicPost a reply Page 4 of 7   [ 101 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Tue Jan 27, 2009 8:12 pm
Survey says p0304 Cyl four mis fire. now why would it be doing that with shiny new plugs? I cleared it and if it pops up again paul shall i let you dig deeper?
PostPosted: Tue Jan 27, 2009 8:32 pm
When was the last time you had a distro cap and rotor?
PostPosted: Tue Jan 27, 2009 8:50 pm
Hm it was before i owned it so over sixty k for sure how long do those live normally so i can look back through the records
PostPosted: Tue Jan 27, 2009 8:59 pm
we change them every 48k but they dont need to be changed every 48k. This is something easy too look at, 3 screws on the rotor and you can look to see what the contacts are like inside.
Image = bad
Image = poor spark
PostPosted: Tue Jan 27, 2009 9:06 pm
Would that explain the other symptoms as well (no guts when cold)?
PostPosted: Tue Jan 27, 2009 9:16 pm
Possiby, but I do believe there is more at work here then just spark plugs. As Matt said about the O2 sensors though we have seen a failed O2 sensor take out the other one too. I would like to see what your Maf is reading when hot.
Before you get some crazy ideas in your head too these are a bunch of variables that would be checked when trying to figure out what is wrong so don't go assuming that everything is broken.
PostPosted: Tue Jan 27, 2009 9:39 pm
Think we may have to wait until it gets cold again
PostPosted: Tue Jan 27, 2009 10:16 pm
Had a 98-00 R in today that ran like shit because of the ECT sensor and the thermostat was sticky, changed that and ran like a top.
PostPosted: Tue Jan 27, 2009 10:22 pm
Edicius wrote:
ECT sensor
=Engine Coolant Temperature Sensor... :wink:
PostPosted: Tue Jan 27, 2009 10:50 pm
Thanks dale! so honestly the things that might be are all nothing i can do at home eh well aside from checking the distributer cap...i may be able to scam a torch bearer tomorrow night my street lights suck so if i make it in tomorrow without throwing a code i will at least check that
PostPosted: Tue Jan 27, 2009 10:53 pm
You should really replace the stuff you have no idea how old it is- cap and rotor, plug wires, filters, all the maintenance stuff (EGR system, other new volvo stuff I don't know about maybe). Regular maintenance goes a long way.
PostPosted: Wed Jan 28, 2009 6:04 am
Bring it in today if you can,or i'll go and pick up your car.
so it has a lambda fault now and a misfire...very interesting..
is it happening all the time now or sparadic..
and what happen you broke your fingers and can't call. :wink: :wink: Kat
Bert & Jacks Auto Service
129 17th ave S.E
228-7078
Paul
PostPosted: Wed Jan 28, 2009 7:07 am
Mis fires under harder acceleration me thinks...Lol and Paul I know you check here from work and by the time i pulled the code it was seven - too late to give call lol. I will leave early and bring her in this morning. Could not bring her in yesterday since i had to pick Peach up in Airdrie before six
PostPosted: Wed Jan 28, 2009 9:35 am
ps. Miss Viv will now be the car formerly known as Miss Viv.
Her new name is Christine :twisted:
PostPosted: Wed Jan 28, 2009 8:57 pm
I dont get it.
