It is currently Mon May 04, 2026 2:11 am
Post a new topicPost a reply Page 7 of 7   [ 101 posts ]
Go to page Previous  1 ... 3, 4, 5, 6, 7
PostPosted: Sun Feb 08, 2009 10:40 am
thats the only hose that ever splits,but Christine never had an evap fault very interesting.
we customizied tools for this procedure and it will require one of your arteries.
see you Monday.
Paolo
Bert & Jacks Auto Service
129 17th ave S.E
228-7078
Paul
PostPosted: Sun Feb 08, 2009 11:07 am
Ian you are a bad influence lol thoughts from the rest of the peanut gallery?
PostPosted: Sun Feb 08, 2009 6:45 pm
Easy peezy to change that mother. That little line usually clogs up with gunk though. I've cleaned them out a couple times but its easiest to just replace it.
PostPosted: Fri Feb 13, 2009 9:22 pm
injectors have been ruled out pulled TWO codes tonight both cyl four mis fires. What next?
PostPosted: Sat Feb 14, 2009 8:47 am
Did you use the Cross??
You have :
new spark plugs,distributor cap..
you rotated the injectors.
leak down test was good.
Vacumn line is repaired.
Replace cyl 4 sparkplug wire next.
it tested fine in the shop,there was no spark leakage but weather conditions could play a role.
And we should do a running Compression test and a Vacumn gauge reading.
129 17th ave S.E
228-7078
Paul
PostPosted: Sat Feb 14, 2009 9:51 am
possible cross fire between cylinders? (I know you mentioned wires were OK, but that is worth looking at the wire routing)
The other idea is Matt's, a lifter or valve hanging open
PostPosted: Sat Feb 14, 2009 10:31 am
Lol i will get this car to stage 0 just trying to figure out this issue. I will hunt for some goodies on tuesday sigh if anyone wants fcp or ipd goodies let me know soon lol I needs me some other goodies i forgot about in my last order
PostPosted: Sat Feb 14, 2009 10:33 am
Ps how do we test Matt's idea?
PostPosted: Wed Feb 25, 2009 9:19 pm
An update! Since it was so bitterly cold I left the car at the shop for fear of the problem coming back. Found that I had a bad wire it got burned lol so we have a used one in there for now - i broke my boogies Lol - no new mis fire codes but the roads were not in a boost able way so time will tell
PostPosted: Wed Feb 25, 2009 9:43 pm
it's not a burn't out wire......
it's a small pin hole burn in the spark plug connector.
just like your cupcakes. :lol: :lol:
129 17th ave S.E
228-7078
Paul
PostPosted: Thu Feb 26, 2009 6:37 am
Leave my muffins out of this lol
