It is currently Fri Mar 20, 2026 2:18 am
 Post subject: Resolution Number 1 - Start Building 122 Wagon
PostPosted: Tue Jan 01, 2008 5:25 pm
As many know, I want a 122 wagon to go with the Canuck and have to sell off my Jaguar project to have this entire thing come to life. Now that we have 2 dogs (and the puppy keeps getting bigger!!) I can argue for a wagon and not have to base my lunacy on just wanting one (never thought there could be alternate reasons to have pets). I spotted the following link on Turbobricks - this is what I've been thinking about for the past couple of months. Check out the 20 valve bundle of joy in this 1800ES, not a 122 but they are physically the same. B5254T FTW! I've been through the white block swap pages and there is a lot of stuff to resolve - but the execution in this dude's swap is eye popping.
http://volvo1800pictures.com/a_ES_73_10 ... d_2219.htm
PostPosted: Tue Jan 01, 2008 5:38 pm
holy god. that'll be a fun one!
PostPosted: Tue Jan 01, 2008 6:55 pm
GOD :shock: I would trade the Volvord for that :supz:
PostPosted: Tue Jan 01, 2008 7:44 pm
Let's not get crazy now...but an easy 225 hp seemed like a good idea to me. I hear you can wring almost 300 out of the 5 cyl with a performance chip.
PostPosted: Tue Jan 01, 2008 7:54 pm
does it have a turbo in it?
PostPosted: Tue Jan 01, 2008 8:06 pm
Yup...TDHL0419T tells you that...
PostPosted: Tue Jan 01, 2008 8:07 pm
shh....when i went to see the pictures click on em to make t hem bigger, it resized itself to illegibility again. but now that you posted em all big and sexy like...
so...is that kinda the same engine I have except from 97?
PostPosted: Tue Jan 01, 2008 8:15 pm
Pretty much...
PostPosted: Tue Jan 01, 2008 8:17 pm
hmm....where did 11 horses go? thought i had 236 base...
dang. more competition for me ;) better get used to havin my ass whooped ;)
PostPosted: Tue Jan 01, 2008 8:23 pm
Keep in mind a 122 is likely close to 500 pounds lighter than your car. That makes up for a lot of HP...
PostPosted: Wed Jan 02, 2008 8:31 am
Kat, you've got the B5234FT or one of it's derivitaves, which is the 2.3 litre low compression high boost turbo engine. It's got a smaller bore than the B5254T for thicker cylinder walls and more toughness. The B5254T is a low boost high compression turbo motor: it doesn't have the same potential as you do, and it runs lots less boost than yours does stock. I think your car runs 0.7 Bar boost stock, and that one runs 0.4 Bar stock.
Craig, I might have a few bits you'd be interested in...
Back to the 1800... Damn, that's a clean install!
PostPosted: Wed Jan 02, 2008 8:49 am
ahh thanks matt :)
PostPosted: Wed Jan 02, 2008 10:14 am
I'm all ears...and either the 2.3 or 2.5 would suit me just fine. I agree the 2.3 has more potential, but at some point I have to consider what I can actually find. I've seen the B5234T on E-Bay for under $500 without the harness. Maybe I should just forget about my misadventures into B20 land :lol:
PostPosted: Wed Jan 02, 2008 6:17 pm
Ooooooo....this is sounding mighty interesting!
I was shocked the whiteblock would fit into an 1800, but then I realized I really didn't know anything about the dimensions of said engine. How does it compare size-wise to the redblock? And how does the size of the 122 engine bay compare to the 1800, besides being not as tall?
That ES is sick.
PostPosted: Wed Jan 02, 2008 11:51 pm
That ES is sick.
The engine bays are around the same dimensions...remember the 1800 is basically a rebodied 122. If I needed more room, the radiator core support could be moved forward 6" very easily. I suspect I'll have to massage the metal on the exhaust side to accomodate the turbo. I could also make use of the area in the front fender well - the wheel clearance is rather generous and if I needed to I could rework the inner fender.
