It is currently Tue May 05, 2026 10:20 pm
 Post subject: wheel spacers on my 265.0
PostPosted: Thu Mar 06, 2008 7:16 pm
Just got my 32mm rears from Dale, dying to see them on the car.Will put the 25's I have now on the front,instead of the 20's on at the moment. I will post some pics as soon as I install them,with my other wheels of course.Gosh,the weather is getting so nice,I should get some of the repairs done on my car,Gotta pull the engine again,both head gaskets are leaking oil,and I want to repair the clutch release arm,etc,etc. You know,all the wonders of Fuel injection these days and I still cant get it running properly,I have spent a small fortune on parts(injectors,computers,sensors.....) If I had to start over I would probably have put a carburetor on it,way cheaper in the long run.Probably the best improvements I made last year, were the TruTrac,the Bilsteins,and an aluminium Flywheel,the latter makes it feel like I gained 50 hp HEE,HEE! You know what my worst problem is,When I finally run out of things to repair/modify I will probably bore with it, and I will have to get some thing else and start all over again.
 Post subject: Re: wheel spacers on my 265.0
PostPosted: Thu Mar 06, 2008 8:08 pm
Ya, that never happens to anyone around here :P
PostPosted: Fri Mar 07, 2008 9:47 am
...is it possible to be finished with a car?
