It is currently Tue Mar 17, 2026 9:26 pm
 Post subject: brake light issue
PostPosted: Wed May 06, 2009 11:53 pm
so I was leaving work today and i noticed, in the reflection of another car, that my brake lights wernt working. so i pulled back into the stall opened the trunk and checked the bulbs. both were fine. so i drove home with no brake lights and started to try and figure things out.
using my multimeter i figured a few things out,
1) power isn't getting back there.
2) the fuse is fine.
3) the brake light switch (attached to the brake pedal) works
any suggestions?
Doug
 Post subject: Re: brake light issue
PostPosted: Thu May 07, 2009 1:09 am
dead relay perhaps?
PostPosted: Thu May 07, 2009 7:36 am
- Follow your logical diagnosis,
- Brake light getting power - good
- Check the light "burn-out relay" in the fuse box, is power going in and getting out?
- If relay working start tracing that wire back looking for a break or open, start in the trunk where the wiring is more exposed, then work forward, that harness runs down the left kick pannel.
Users browsing this forum: No registered users and 13 guests
