Fifty posts, then-what? I WANNA BE A CREATIVE ENGINEER GENIUS!!!
Overdrive switch, mmmmmmm. I don't mind just buying one myself, Craig, you have enough to do, but thanks for offering. And I guess a relay too - I did not know the relay part. Geez, I think the last one I had I just wired it into a spare heater switch. And the one before that a toggle. I'll look it up in the Haynes manual and see if there is a relay in there.
Yessss and then there is the momentary contact question, DAAAALE? Hmmmmm. Doesn't make sense: drive down the hwy, switch-on overdrive. Flip switch off, overdrive goes off. I don't see a momentary switch working. I have an illuminated pull-switch (and I already drilled a hole in the dash for it), I think I'll just use that, even though it is (shrug) plastic.
Creative Engineer Genius (part-time)
