It is currently Thu Mar 19, 2026 10:37 pm
 Post subject: trailer wiring
PostPosted: Wed Jun 30, 2010 9:20 pm
question:
While wiring up my tailights, (brake, turn, clearance), I got confused...maybe thought about it too much
Okay, all clearence lights, (front ambers, rear reds) are getting powered by a brown power wire
This brown power wire needs to supply power to the tailights for clearance as well
For the turn/brake function there is a seperate green wire that needs to be wired to the tailight
If I wire the green wire to the brown wire in a series fashion is this gonna F up my clearence markers? making them act as a brake light or turn signal or does the filament bulb prevent this?
I am confused of what to do with the tailight, as there is only two wires coming out the back, a black and a green, power and ground, no?
thanks for the help
 Post subject: Re: trailer wiring
PostPosted: Thu Jul 01, 2010 6:45 am
Minimum wiring for the trailer will have 4 wires using single 1157 bulbs on each side
-Left turn light
-Right turn light
-Tail lights
-Ground
Additional circuits can add:
-seperate turn & brake lights
-trailer brakes
-Power feed for battery
PostPosted: Thu Jul 01, 2010 11:43 am
yeah I have that pic, I am doing a 7 pin wiring
in the pic there are what appears to be seperate clearence and stop/turn connection points, my question is more of if I connect these to the same point or terminal will it cause problems?
PostPosted: Thu Jul 01, 2010 2:55 pm
Iirc, you need a taillight converter.
