It is currently Thu May 07, 2026 9:37 pm
 Post subject: What's Craig Cooking up this time?
PostPosted: Sun Jul 25, 2010 11:58 am
It's been a short weekend, but I've managed to get a few car projects done that I thought I would share. First up - Greg needed his 90+ manifold cracks fixed, so I put the mani in the BBQ and gave it a pre-heat to 400 degrees F after I had ground out the cracks. The I welded it up with Ni rod. That will hold for a while.
The marks on the weld are from my chipping hammer.
Next, I've been trying to get rid of the washer fluid reservoir in the 122 as it just doesn't fit the theme of the car. So I welded up an aluminum tank that holds 1.3 L of fluid and has an external replaceable pump. There's still some wiring and work to do on this project, but it turned out great.
The caps are a stock part available from Summit by the way.
Cap and bung.
Tank end caps.
Pre-weld fit up.
Tank body.
Welded up.
Final brushed finish with pump installed.
Installed.
 Post subject: Re: What's Craig Cooking up this time?
PostPosted: Sun Jul 25, 2010 1:45 pm
Nice! Thanks Craig!
No polished finish on the tank?
PostPosted: Sun Jul 25, 2010 7:08 pm
I suppose I should polish it given that the other tank is polished...
PostPosted: Wed Jul 28, 2010 9:15 pm
Ok, peer pressure at work. I had to change out the fasteners and wire up the washer bottle, so I decided to polish it while it was out. Matches the rest of the engine bay now.
That new pump sure does work well - it really blasts the fluid on the windshield. The old Princess Auto pump just barely worked. I'm really stoked about this addition.
PostPosted: Wed Jul 28, 2010 9:43 pm
Looks awesome, nice work.
PostPosted: Wed Jul 28, 2010 11:31 pm
Nice!
PostPosted: Tue Aug 17, 2010 8:38 pm
Hi - wot's the shiney thing on the other-side?? I'm stumped.
PostPosted: Wed Aug 18, 2010 9:21 am
Overflow for my rad.
