It is currently Thu Mar 19, 2026 4:13 pm
Post a new topicPost a reply Page 1 of 3   [ 31 posts ]
Go to page 1, 2, 3  Next
 Post subject: Looking for Snow Tires
PostPosted: Sun Dec 12, 2010 10:57 am
Hi Everyone, new guy here.
Am wondering if anyone knows of someone selling snow tires with or without rims for an 06 S40??? My present tires are 205 50 r17
Much appreciated
Bill :)
Volvo S40
 Post subject: Re: Looking for Snow Tires
PostPosted: Sun Dec 12, 2010 2:24 pm
Hi Bill,
I doubt it...anyone with a set has them on a car at the moment. There have been sets pop up from time to time on Kijiji. Keep looking.
PostPosted: Sun Dec 12, 2010 3:24 pm
Hi Bill
As 122_Canuck said Kijiji. That and a tire size calculator.
http://www.miata.net/garage/tirecalc.html
I am fairly sure that your 17's are the up size optional tires so you should be able to go down to 16 inch tires. Easier to get and cheaper. Then get a set of winter steel rims from Volvo and you are set.
205/55R16 seems to be the closest size match. Lots of them on Kijiji.
This is what I did on both of our cars.
2005 S60 2.5T is Da Bosses (she who must be obeyed)
2008 V70 3.2 is mine and the Banks--Party time not the Banks anymore!
PostPosted: Sun Dec 12, 2010 3:52 pm
http://calgary.kijiji.ca/c-cars-vehicle ... Z247917506
Seems like about what you need although it seems to me the S40 may have a different centerbore than the other cars. Bolt pattern will be correct though...
PostPosted: Sun Dec 12, 2010 4:23 pm
Thanks for the info guys, much appreciated.
Will recheck Kijiji again.
thanks
Volvo S40
PostPosted: Sun Dec 12, 2010 6:08 pm
Check Kijiji Alberta. There are a few sets in Edmonton at the moment too...
PostPosted: Sun Dec 12, 2010 7:03 pm
Thanks Pylon, I will check it out.
Volvo S40
PostPosted: Thu Dec 16, 2010 9:20 pm
http://alberta.kijiji.ca/c-cars-vehicle ... Z248833723
PostPosted: Thu Dec 16, 2010 9:32 pm
Thanks Dale they look good
I had $800 to spend but have my tax audit and owe another $400.00 ouch
Thanks anyways appreciate your help
bill :)
Volvo S40
PostPosted: Fri Dec 17, 2010 9:10 am
You should be able to swing a set for $100 each. There were several in the fall at around that price.
PostPosted: Fri Dec 17, 2010 12:36 pm
The problem I am having is finding rims with a 5X108 bolt sizing. for the Volvo
Volvo S40
PostPosted: Fri Dec 17, 2010 12:50 pm
The 5x108 isn't the problem, Ford (fwd) and modern Jaguar and Volvo and Ferrari all use that bolt pattern. It's your 67.1mm center bore.
Any aftermarket wheel that fits the above cars should have a universal center bore that takes a spacer ring, though. Get the right ring for the wheel and your hub and you're set.
PostPosted: Fri Dec 17, 2010 3:08 pm
Thanks Ugly duck, this is getting more complicated as it goes on, I knew I should have paid better attention when my dad wad trying to teach me car stuff.
Bill :)
Volvo S40
PostPosted: Fri Dec 17, 2010 4:44 pm
Wait a tick - I'm getting conflicting search results. It's a 4x108, one source says, and another says 5x108. I'm pretty sure they changed to 5 bolts at one point, didn't they?
Edit - kkk, disregard my earlier post. Swedespeed says that it's 63.9 center bore with a 5x108 bolt circle. Ford uses a 63.4 center bore, so the Ford factory wheels won't fit, but all other Volvo FWD wheels will, though they'll be located only by the studs (all other Volvos have 65.1 center bore.)
Edit too - and another post on Swedespeed says that they're 63.4, guaranteed. Damn, I hate the intarwebz.
PostPosted: Fri Dec 17, 2010 6:54 pm
My 06 S40 has a 5 bolt pattern I read somewhere its 5 X 108, I currently have summer tires 205-50 r17 with factory steel wheels.
I know nothig about te middle hole size on the wheels or insert, I plead stupid on that. haha
Bill :oops:
Volvo S40
