It is currently Thu May 07, 2026 8:04 am
 Post subject: M5 RIMS
PostPosted: Wed Nov 09, 2011 10:36 am
I have a friend that has some bbs rims off of a bmw m5,they are 17" x 8" and 5 x 120 with an et 20,do you guys know where i can get wheel adapters for it?
 Post subject: Re: M5 RIMS
PostPosted: Wed Nov 09, 2011 11:52 am
Quick answer: you can't. Well you CAN, but you shouldn't.
You'll need a minimum of a 20mm spacer to change bolt pattern, and with a wheel that's got an ET of 20 already, you'll end up with 0 offset. This will make steering rediculous, you'll rub the lips of your fenders, etc.
If you can take care of the fender clearance problems and if you don't mind wrestling a live bear all the time, Dale might still be able to get you some. You'll need to give him the center bore size and the lug size you want to use.
PostPosted: Wed Nov 09, 2011 12:46 pm
Get an m5 to put them on. Youll be happier with the results (says the ex m5 owner)
PostPosted: Wed Nov 09, 2011 12:54 pm
why would the car handle like a bear,you lost me on that one.
PostPosted: Wed Nov 09, 2011 1:57 pm
Wide wheels, strut suspension with no caster and lots of SAI, and zero offset would make the car want to change direction every time it hits a rut, groove, or bump in the road. I've probably got some 20mm spacers you can stick behind your stock wheels to see the effect if you like, and then you can multiply that by the wider/lower profile tires of the M5 wheels.
PostPosted: Wed Nov 09, 2011 4:19 pm
ok i see what your saying now.
sure is hard to find nice rims for a 240
PostPosted: Wed Nov 09, 2011 5:58 pm
Not really. Just find something in the ET-40 and more range so you can use adapters. I take it you're not a fan of any of the FWD Volvo wheels?
PostPosted: Thu Nov 10, 2011 9:07 am
How deep are your pockets? $1500 plus shipping and adapters...you're up to $2000 before you have tires mounted...
http://forums.turbobricks.com/showthread.php?t=247014
PostPosted: Thu Nov 10, 2011 12:26 pm
i have deep pockets,just posted a reply how much would spacers be dale
PostPosted: Thu Nov 10, 2011 9:49 pm
I don't do spacers much anymore so they are sort of a one-off deal now. I'm going to say $400 for a set of 4. There are places in the US that will do them for less and get them to you quicker than I can. I'm not trying to turn away business...well, I am sort of...I'm working two jobs right now and don't have the time to deal with machine shops or customers. That said, I'm sure I can do something for you if you're not in a huge hurry.
PostPosted: Tue Nov 15, 2011 11:35 am
do you guyhttp://calgary.kijiji.ca/c-cars-vehi ... 315838346s think that these will fit with spacers
PostPosted: Tue Nov 15, 2011 7:17 pm
Try entering that link again... guyhttp doesn't seem to be recognized :?
PostPosted: Tue Nov 15, 2011 7:26 pm
I dont think you will get a 9in wide rim under the back of a 240.....not without some fender mods anyhoos, Someone correct me if I am wrong though ???
PostPosted: Tue Nov 15, 2011 9:59 pm
I took out the "guy" and kijiji said the ad doesn't exist anymore??
