It is currently Mon May 04, 2026 10:08 am
Go to page 1, 2, 3  Next
 Post subject: Would you build a b23 or keep watching for a b230?
PostPosted: Sun Jul 06, 2014 7:11 pm
I've been slowly collecting parts to build a 242 into what I've always wanted. I finally found a nice body a month ago.
Anyways. Car will be driven on the street and as many track days as possible.
My goal is 401whp (wierd goal I know). Strong under the curve power.
It's going to have all the supporting mods.
16v head.
I have
2 b23e blocks. (Not much if any ridging)
1 b230ft squirter block with a good amount of ridge.
1 b230ft early block. I was told it's an 89 but I haven't been into it so don't know.
Honestly the b23e blocks are probably in the better shape without actually measuring them out. (All the blocks are at my dads in kamloops).
I could put squirter a in the b23 block. It has a forged crank. The millet crank gear is available for it from yoshi (I'd be going with one on the b230 anyways).
Should I bring those blocks up here and have them sonic tested or would you just keep looking for a b230 block that is in better shape. I'm not in a rush for anything. Pulling a block a the jy doesn't really excite me, and there hasn't really been a goo candidate in a while anyways.
Thoughts?
 Post subject: Re: Would you build a b23 or keep watching for a b230?
PostPosted: Mon Jul 07, 2014 8:47 am
Hmmm, not sure on this one as I've not finished my swap yet and I'm not doing a 16V or looking for magic numbers. The main advantage of the B23 is the forged internals...I'm not sure this even matters for 100 hp/hole. I haven't heard of anyone breaking a cast crank at or around those figures. If B230FT was an option, then I'd do the later blocks with the thrust bearing in the normal rear bearing position. If I was doing it, and I am, then just do it right and use the best of everything. It's not cool to be sitting on the side of the road with a windowed block.
In my swap, I've added squirters and h-beams and some core plug retainers. I have a B23E coming out of my car that has no/minimal ridge (last time I had the head off...4 years ago) but it needs to be honed to first oversize or have oversize rings installed. It's available - but I don't know if this gets you anything you don't have. I do know that Mahle just did a run of first oversized B230FT pistons (I have a set), but the B23 pistons are rare. If you're doing H-beams, then you could go with custom pistons.
PostPosted: Mon Jul 07, 2014 12:21 pm
I'm going to use h-beams and forged pistons. I'll likely use the RSI stuff and avoid JVaB.
The forged crank interests me. I'm just having a hard time finding a nice b230 block
PostPosted: Mon Jul 07, 2014 4:09 pm
http://newlondon.craigslist.org/pts/4527297334.html
PostPosted: Mon Jul 07, 2014 4:17 pm
Mmmmmmmmmmmm....
PostPosted: Mon Jul 07, 2014 9:56 pm
Not enough valves.
PostPosted: Mon Jul 07, 2014 10:05 pm
Meh...they're overrated...
PostPosted: Mon Jul 07, 2014 10:11 pm
I can think of 16 valves that may be a whole lot easier to do.... :)
PostPosted: Tue Jul 08, 2014 6:59 am
I like the B23, myself, but the right year of a B230 is strong enough for most. The early B230s aren't worth spit, in my eyes, and finding a late B230 is about as easy as finding a B23. If you're going with custom rods & pistons, I can't think of a lot of reasons to choose the B230 over the B23, considering the level you want to play at, but the same argument could be made the other way.
PostPosted: Thu Jul 17, 2014 8:53 am
Vmax 200mph w00t!
If you're thinking you might want to avoid RSI stuff and use JVAB i might have a set of h-beams for you :roll:
94' 944t "The Good One"
87' 780 5.0L V8
PostPosted: Fri Jul 18, 2014 10:14 pm
You have JVaB rods? B230 or b23?
RSI has a clearance sale on the 96.5 long rod 16v pistons for a b23. I contemplated picking them up and doing a b23.
PostPosted: Sat Jul 19, 2014 1:53 pm
Vmax 200mph w00t!
B230. They're from kenny howard, so i dont know if they are actually jvab or not...part of that tbrix group buy a few years ago
87' 780 5.0L V8
PostPosted: Sat Jul 19, 2014 3:25 pm
I think his group buy was for the regular old china rods.
PostPosted: Sat Jul 19, 2014 8:42 pm
I'm not wanting to kill a sale - but JVAB rods are for sale all the time on eBay from the factory. I've bought a set from John and a set from eBay - same thing. Anyway, don't get the ARP 2000's from China, they will be counterfeit. Every length is available for around $250 a set.
Just finished prepping my block for paint - enjoy.
PostPosted: Sat Jul 19, 2014 9:43 pm
Vmax 200mph w00t!
ooh fancy! =D>
87' 780 5.0L V8
