It is currently Wed Mar 25, 2026 5:44 am
 Post subject: Did I kill it?
PostPosted: Sun Apr 26, 2015 8:49 am
I was driving up a hill when out of nowhere I lost power and something sounded like it was freewheeling. Almost instantly the car stalled and I limped to the curb. The engine turned over but sounded pretty dead, like no spark. I'm wondering if that sounds like that fibre timing gear getting stripped?
 Post subject: Re: Did I kill it?
PostPosted: Sun Apr 26, 2015 9:25 am
Post a video of what it sounds like when it's cranking over?
PostPosted: Mon Apr 27, 2015 3:36 pm
Try this for sound
PostPosted: Tue Apr 28, 2015 7:19 am
Yup, that could very well be the timing gear.
PostPosted: Tue Apr 28, 2015 10:08 am
I've had one go before and it would run but sounded like a diesel. Very noisy. Stick a compression tester on it and see what happens. Pull off the valve cover and move the to TDC on 1...valves open or closed. It should be closed...both rockers should wiggle - no pressure. It not I suspect you may have lost that engine. Could be much simpler.
PostPosted: Tue Apr 28, 2015 5:02 pm
Timing gear makes sense, certainly the easiest fix. I had one go about 8 years ago on the way back from a high-speed airport run. Towed it home, had it running again that evening. Let me know if you want a used one, I think there's a couple in the garage.
PostPosted: Tue Apr 28, 2015 9:51 pm
Hey thanks for the offer on the gear but I have a couple kicking around. Work is kind of getting back to normal (seasonal), but probably within a week or two I'll be able to have a look at Craigs and other suggestions. I would like to limp that thing around for a little while yet!
