It is currently Thu Mar 19, 2026 6:04 pm
 Post subject: Best turbo setup i've ever seen - lol :)
PostPosted: Thu Nov 30, 2006 7:21 am
Stupidly big turbo from tractor
5" downpipe with no muffler
open to air wastegate set at 10 psi welded to exhaust housing of turbo
intake plumbing made of PVC
secondaries running 120+ jets on the carb
blow off valve threaded into carb-hat
== Lolz :twisted:
PostPosted: Thu Nov 30, 2006 8:14 am
I especially like the purple glue and the brackets welded to the valve covers.
... and I thought I had a lean bog :?
PostPosted: Thu Nov 30, 2006 9:27 am
I wonder if the pipe off the turbo will melt....
And what's that purple crap holding the PVC together? Some kinda pipe adhesive?
PostPosted: Thu Nov 30, 2006 9:42 am
That's the proper PVC dope. It's a 2 part joint maker, the purple stuff is a cleaner-primer that you paint on everything first, then you goop it up with this grey stuff and SLAM them together - they set up in a few seconds, cure in a minute or two.
Used on golf course irrigation systems... saw 7 years of that stuff!
You know that stuff doesn't show up on a hospital X-ray?
PostPosted: Thu Nov 30, 2006 9:59 am
umm...how do you know that?!the x-ray part...or do i want to know :rolleyes:
