It is currently Thu Mar 19, 2026 10:56 pm
 Post subject: air fuel gauge?
PostPosted: Tue Feb 13, 2007 9:34 pm
4 Valves per cylinder!
I am trying to install an air/fuel gauge, and it is suppose to be attached to the oxygen sensor at the ECU. I thought i could just splice into the wire - but it turns out to be a single wire, wrapped by another wire.
Can i splice into this double wire - if so how?
Or
How do i find the ECU oxygen sensor?
Thanks
Houston
PostPosted: Wed Feb 14, 2007 12:28 am
is it a double wire coming all the way from the O2 sensor? How many sensors do you have? I know on my k-jet car it has a one wire sensor at the bottom of the manifold and thats it, I was able to just put the a/f gauge pick-up at the connector.
PostPosted: Wed Feb 14, 2007 7:39 am
The O2 sensor wire is usually shielded to prevent outside interference or induction. It is best to splice into the car harness which is often unsheilded
