It is currently Sat May 02, 2026 6:10 pm
 Post subject: Purpose of in-tank fuel pump in 7xx series
PostPosted: Mon Sep 03, 2018 10:35 am
What is the purpose of the in tank fuel pump?
It is specific to the cars with IRS due to the layout of the tank(s)?
 Post subject: Re: Purpose of in-tank fuel pump in 7xx series
PostPosted: Mon Sep 03, 2018 9:11 pm
It feeds fuel to the main pump. No other way to get fuel out of the tank. Not sure about the IRS question - but I doubt it.
PostPosted: Tue Sep 04, 2018 9:30 am
The IRS has a saddle tank, but there's still only one in-tank pump and it's not to get fuel out of the far side of the tank. As Craig said, the main pump cannot "pull" fuel - it must be fed fuel from the in-tank pump. Generally the failure mode shows up as the car running fine until about half a tank, then a noisy main pump, then bucking around corners, then dead stalling. Add more fuel and it runs again.
PostPosted: Tue Sep 04, 2018 10:43 am
What is the common fix for the in tank fuel pump?
Replacement, broken hose, leaky hose?
PostPosted: Tue Sep 04, 2018 12:13 pm
All of the above. I've seen all three.
