It is currently Mon May 04, 2026 3:34 am
Post a new topicPost a reply Page 6 of 11   [ 155 posts ]
Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 11  Next
PostPosted: Tue Dec 22, 2015 3:30 pm
It's a base/clear urethane. Pro-Spray and Eurostar, or something like that. I have an industrial coating place I go to, not a real body shop place. I'm not sure about the test cards but I will ask and I will bring in the can when I buy a gallon for the body. It mixes 1:1 but with the jambs and door backsides I now need to spray, I'm now kind of forced to buy a lot.
PostPosted: Tue Dec 22, 2015 10:39 pm
Probably only 2 gallons sprayable - that's about what the 242 took.
PostPosted: Wed Dec 30, 2015 5:22 pm
I got some fiddly stuff done today, which took all day but I finally have the front suspension mapped.
With the 550 lb-in springs a 1G hit should compress the suspension 3.5", but I think I only have about 2.5" before hitting the bump stops so I'm assuming a "normal" travel range of about 5".
Total wheel travel is 7" from bump stop to bump stop. At ride height I set the static camber to be 1.1 degrees negative, and the average camber gain over the 2.5" of bump is about 1°/inch, while the average camber loss over 2.5" droop is about 0.8°/inch. The average camber loss over the full 4.5" of droop is about 0.4°/inch, so it actually slows right down in that last 2" of droop.
I set the static toe at 1/8" in at 23", at ride height. At full compression it's the same as at ride height, 1/8". At 2.5" droop the toe is less than 3/16", so the variance over the 5" of normal travel is less than 1/16". At full droop this rises to 5/16" toe in, but that's not so bad because there's no load on the tires at this point so toe is irrelevant.
I think this shit's nailed down.
PostPosted: Wed Dec 30, 2015 5:55 pm
Is that the stock suspension or the one with the lowered UCA?
PostPosted: Wed Dec 30, 2015 6:02 pm
This is for the modified one. I lowered the dogbone by 1.25", and the added camber gain should give toe-out on bump but the bump steer can be adjusted by tipping the crossmember. I started with the crossmember tipped all the way up (no caster shims between the front of the crossy and the front frame horn) and this is what I got. When I ran it like this, but with the stock dogbone position, I got a lot of bump steer. I thought I'd need to play with it a lot more, but sometimes you get lucky!
PostPosted: Mon Jan 04, 2016 1:21 pm
Here's a shot of the (temporarily) installed product. Eagle-eyed viewers can see a 3/16" bar of stainless bolted to the original mounts as well as behind the dogbone. This is not the method of lowering the dogbone, it is the top end of a shim/reinforcement plate. It's probably not necessary for strength, but "strong enough" isn't strong enough for me:
I lost concentration for a few days, and fell inside the car. Craig's super-clean and rust free 122 still had rust where the firewall meets the floorboards, so I pulled up the seam sealer in this location. Yup, no holes here! It's a little surface rust, and I'll take care of it when I redo the cheezy patches on the kick panels and clean up the surface rust at the floor "drain" holes.
I did find a little rust, though:
I had a nasty diamond-tufted dash upholstery abortion thing going on, which I ripped off to find a destroyed dash cap, which I also ripped off to find this. I ground it all down, neutralized the rust, and coated it with some POR-15.
While I had the dash cap off, I got a little more sidetracked:
The drive gear on my speedo was very noisy and would rattle at highway speeds. The coating on the brass fascia was also flaking off, the lens was a little foggy, and the chrome surround wasn't looking too hot. I pulled it all apart and scraped the rest of the grey coating off the fascia, polished the clear plastic, and gave the inside of the cluster a coat of fresh paint. I really dig the gold look so instead of painting it grey, I scrubbed the fascia with steel wool and clearcoated it so it won't discolour. I reassembled the speedo with a drive gear from a donor speedo, and called it done. No, I didn't reset the odometer while I was at it.
Installed:
I have an old but not TERRIBLE dash cap to go back on. Good enough for the next guy.
I also got the pedals, much of the hydraulics, and most of the wiring harness installed. No pix of that, but more later.
PostPosted: Mon Jan 04, 2016 3:12 pm
Sweet Matt! And wow!! I had no idea a dash could look like that!
PostPosted: Mon Jan 04, 2016 4:47 pm
I know, me neither. The windshield was leaking, I knew that, but I assumed it would hit the floor, soak the jute, and kill the firewall/floor panels. Instead it got soaked up between the foam and the dash panel and attacked that.
PostPosted: Sat Jan 09, 2016 9:07 am
Wow. Amazing work on the speedo. You've motivated me to do the same!
1967 Volvo 122S
1969 Lotus Elan +2
2000 Subaru Impreza
PostPosted: Sat Jan 09, 2016 8:53 pm
Today I got most of the engine work done, but like a bloody idiot I took no photos of the work done. I built an oil pump reinforcement ring out of a 9/16" grade 8 bolt (15/32" hole and 7/16" long, perfect fit) and installed a steel timing gear. The guy who pulled the gear did me no favours though: he hammered the crap out of the crank gear, deforming many of the teeth. I spent much time grinding and checking, filing and checking, testing the mesh with machinist dye, until I was satisfied. A new thrust plate went in too, after I adjusted the fit until it was perfect.
So now the bottom end is pretty much bulletproof and the way it should have been when I put it together the first time.
PostPosted: Sun Jan 10, 2016 9:04 pm
For posterity, not for art:
After buttoning up the engine it was time to get it back home. The flywheel I was running had some ring gear issues, and when I went to spin it around I noticed that someone had already done it, so I rummaged around and came up with another flywheel. The one out of my 123 GT was in nice shape, I sort of forgot about it... i've never seen one that hadn't been surfaced before, there's a little step I never knew about.
The cluch was almost new, too!
So on the engine and in the car.
It got a reduction starter and the proper B18 bellhousing (was using a B20 before with no way of closing off the bottom half), and I test fit the big rad. Looks like I need to do something about the fan...
I don't want to run an electric fan but will if I have to, Craig suggested I try one of the old metal fans first to gain some space, though it will sacrifice some air movement. Will try tomorrow.
PostPosted: Mon Jan 11, 2016 11:11 am
Sweet Matt! Love seeing it in the car. Wiring looks tidy too.
PostPosted: Mon Jan 11, 2016 12:01 pm
More great work Matt, and fast too. Seeing that dash made me queasy thinking what can be hiding in cars of this vintage...
PostPosted: Mon Jan 11, 2016 6:33 pm
I've never seen a step like that before. That's not stock. The little step to the inside is there for clearance and a sure sign of resurfacing is when it's gone or almost gone. What clutch is that? The PP looks different to me - not a Sachs?
PostPosted: Mon Jan 11, 2016 8:50 pm
I don't know, maybe the PO tried to get more grip from the clutch and had a step machined into it. The clutch is obviously newer than the mileage of the car even if you assume it was never wrapped. I remember seeing a name on the diaphragm cover, but I can't remember if it was Borg & Beck or Fitchel & Sachs or something else.
I think it was a Sachs but don't trust my memory. It did suggest it was made in America thiugh.
