It is currently Sun May 03, 2026 7:22 am
Post a new topicPost a reply Page 3 of 3   [ 42 posts ]
Go to page Previous  1, 2, 3
 Post subject: Re: wanted 240 740
PostPosted: Thu Feb 12, 2015 12:33 pm
I'm looking sub $2000 just something a little rough but drive able that I can make into what I want
90 740tic
PostPosted: Tue Feb 17, 2015 6:54 pm
http://vancouver.en.craigslist.ca/van/c ... 30576.html
http://vancouver.en.craigslist.ca/van/c ... 27328.html
PostPosted: Tue Feb 17, 2015 7:09 pm
Thanks for the suggestions but trying to stay local
90 740tic
PostPosted: Tue Feb 17, 2015 8:23 pm
A lot of the work is done for you on mine. What do you want to make it into? That photo is coming up to 5 years old. The car isn't quite as pretty now. Here is a list off the top of my head...
B23ET clone engine- B23 block/crank/rods with B23ET pistons- 9.3:1 c/r
405 head
M46 transmission
New Spec stage 0 clutch...less than 5000 km on the clutch
Lightened flat flywheel with LH2.4 trigger holes drilled into the perimeter
IPD sway bars front and rear
Front lower chassis braces
Cut stock front springs
Some progressive "lowering" springs on the rear that actually are stock height or maybe even higher
Bilstein HD shocks on the rear...less than 5000 km on them
Bilstein Touring front struts- less than 5000 km on them
Genuine Volvo accessory front and rear bumper covers and side skirts- the is the SE kit offered on the '91- I have the rear spoiler too but took it off.
Paint is original except for the front cowl, body kit and rear fender arches
Interior is original
Euro headlights- they're badly cracked but I have replacement lenses.
Brand new battery
It needs some tuning...doesn't like idling when it's cold. I suspect it's the Idle Air Control but never got around to changing it.
It needs an in-tank fuel pump...the inline pump is complaining and that's typically the reason. I have a new one to go in.
The car drives great and has plenty of power. My wife and I drove it to Victoria last September and the only problem we had was the battery died...it was in a Wal-Mart parking lot so I went in and got a new one. No issues since.
The car is not rolling on Pegasus wheels any longer. It currently sits on 16" TSW Blade wheels. It will need tires.
While $2000 won't buy it, I'm not asking the moon either. It's a 1990 Volvo...I'm realistic about that.
PostPosted: Tue Feb 17, 2015 8:35 pm
That's pretty much everything I would do to my own except body kit. As I like the way the stock body looks pretty much hahaha. Actually a lot more than I had in mind. Pretty much the same for suspension. But all I planned for the engine was 3in turbo back exhaust and a manual boost controller just to get a bit more power But unfortunately the reason I say less than $2000 is because I currently live in a condo and I have no where to store a second car so my car would have to go. And I don't see myself getting much more than maybe $1500 for it. So that basically is my budget. I don't really have a lot extra to put on top of that. I'm a broke ass
90 740tic
PostPosted: Thu Feb 19, 2015 9:37 am
$1500?!?! We agreed on $500!
'89 760TIC - currently for sale.
'03 Silverado RCSB 2WD
'87 Omni GLH clone (in pieces, kinda)
PostPosted: Thu Feb 19, 2015 11:08 am
Hahahaha I never agreed on anything. I can do three payments of $500 each
90 740tic
PostPosted: Fri Feb 20, 2015 3:36 pm
How about a reasonable condition 245? I've got a line on one.
PostPosted: Fri Feb 20, 2015 5:37 pm
I know this is probably blasphemy but I'm no a wagon fan
90 740tic
PostPosted: Fri Feb 20, 2015 5:40 pm
Unless it has a turbo*
90 740tic
PostPosted: Fri Feb 20, 2015 10:39 pm
:shock:
PostPosted: Fri Jun 05, 2015 12:07 pm
Probably selling the 760 this weekend. So if anyone has a line on a turbo manual that would be great as I will be car less hahaha. I've got $2000 straight up and could make payments over time also
90 740tic
