It is currently Sun May 03, 2026 2:54 pm
 Post subject: Clip for Choke Cable on B21 SU Carb Needed
PostPosted: Sun Mar 30, 2008 3:48 pm
OK...I know it's a long shot but I need one. It's not for my car; it's for a buddy. I was checking it over last night because it was difficult to start. While reaching down to loosen off the cable pinch nut, my sleeve touched the clip and sproing! It fell somewhere but didn't hit the ground. I suspect it fell behind the starter motor. Anyhow, it's no longer and the 3 SU carbs I have in the garage are void of this particular clip.
Just to clarify, this is the clip that attaches to the bracket on the back of the carb and holds the choke cable sheath from moving up and down. The B20 SU uses a different clip...checked that already.
 Post subject: Re: Clip for Choke Cable on B21 SU Carb Needed
PostPosted: Sun Mar 30, 2008 7:12 pm
I bet a couple of minutes with that pile of 16 ga you have and you'd have one built. I've got a couple of spare pairs of HIF6's and a set of HIF7's, what model was used on the B21A?
PostPosted: Sun Mar 30, 2008 7:14 pm
The B21A uses an HIF6 carb. I'd try making something but it's a pretty strong spring clip. I'm not sure I can get something to hold tight enough. I might be able to rig up something though...
PostPosted: Sun Mar 30, 2008 8:35 pm
I looked at both my HIF6's and HIF7's and I don't have a clip on either, sorry.
PostPosted: Mon Mar 31, 2008 5:46 pm
Got one from Valentine. $3.65...
PostPosted: Mon Mar 31, 2008 9:03 pm
They still stock parts for SU's...someone call 911, I've fallen off the couch.
PostPosted: Mon Mar 31, 2008 10:18 pm
Well...they had to order it from the warehouse in Toronto but it was still on Canadian soil... :lol:
 Post subject: Choke cable clip
PostPosted: Thu Apr 24, 2008 9:58 pm
I have one If U still need it. I found it at pnp and it was on a '79 245. The carb and all the cables are still there.
