It is currently Sun May 03, 2026 11:19 am
 Post subject: Looking for: TD04 turbo water and oil lines
PostPosted: Mon Nov 10, 2008 6:26 pm
I need water and oil lines from a TD04 turbo, Most importantly I need the banjo bolts.
Let me know
 Post subject: Re: Looking for: TD04 turbo water and oil lines
PostPosted: Mon Nov 10, 2008 8:10 pm
Let me know
Doesn't Earl's make these?
PostPosted: Tue Nov 11, 2008 1:21 am
A trip to Mopac you say? Well i'll check that out if there are none available.
PostPosted: Thu Nov 27, 2008 4:26 am
try at a dodge dealer, they use the td04 on the 2.4 turbo engines, and will have same banjo bolts + copper washers
Let me know
PostPosted: Thu Nov 27, 2008 5:57 pm
Okie dokie, thanks
PostPosted: Fri Nov 28, 2008 5:50 pm
for an FWD volvo (depending what manifold and exhaust housing it has) or RWD with the TD04H-13C on a redblock?
PostPosted: Sun Nov 30, 2008 11:51 am
any really, I can adapt the lines to work for my application.
