It is currently Wed Mar 25, 2026 7:21 am
 Post subject: 1998 V70 R from the US
PostPosted: Sat Apr 03, 2010 11:44 am
This is not my car, just received an email from the group in Colorado that this is for sale. Here is the info from the seller:
Try To Find A Nicer Example Of The One Year Only Saffron - Color Code 435
1 of 113 That Came To North America In 1998
236 hp, 243 lb Torque , AWD Version Of The More Simple 850 Drive Train Before The Large Change That Came In The 1999 Model Year When EveryThing Got More Expensive To Repair, i.e - Flyby Wire Throttle, Software Control Modules, Programmed Keys and Remotes via Software.
This Is Basically An All-Wheel Drive High Pressure Turbo 850 R!
Please See Detailed Pics at
http://s42.photobucket.com/albums/e323/ ... ers/Reily/
It Has A Horizonial Crease On The Left Rear Bumper and A Scratch On The Right Front Fender, Litle Curb Rash On Rims, Not Bent, Other Than This, It Is Nearly Perfect!
Repair History-
Recent Tune Up Including Air Filter, Fuel Filter, Pollen Filter, Spark Plugs, Volvo Blue Coolant/Distilled H2O Flush, Synthetic Castrol Brake Fluid Flush, Transmission Flush With BG Synthetic Fluid, Power Steering Flush With Volvo Green Synthetic, Bevel Gear Drain and Fill, Rear Differential Evacuate and Refill
Timing Belt, Water Pump, Serpentine Belt, Mechanical Tensioner, Idler Roller - 105k Interval!
Dual Exhaust Like The 2000 Models
Rear Spoiler
Newly Dark Tinted Windows
111k Miles - Low Miles
Fender Turn Signals Like The 1999 Models
Dolby Prologic Stereo System
Factory Window Sticker $42k Original Price In 1998
I'm The 2nd Owner
Newer ABS Control Unit, A/C Evaporator, P/S Rack, Both Front Axles, Air Pump
Adjust Turbo To Factory Spec
New Park Brake Cables and Shoes
New Front and Rear Volvo Brand Brake Pads and Rotors
New Volvo Battery
New Thermostat and Coolant Temp Sensor
Oil Changes Every 2.5k Miles With Synthetic, Just Done, 30 miles ago!
No Leaks Anywhere!
This Is A Turn-Key Car! Needs NOTHING But Gas and Oil Changes.
Asking $7.5k - FIRM
Just Got Emissions Done, Just Get Plates
I'll Put That You Paid $500 For It On The Title So You Have Little Tax To Pay!!
 Post subject: Re: 1998 V70 R from the US
PostPosted: Sat Apr 03, 2010 12:37 pm
Not to be rude but when one of these comes in they are generally in poor condition. Usually beat on and when the awd system goes then its $$$ to fix.
