It is currently Fri Mar 20, 2026 9:53 am
 Post subject: anyone got a good flat flywheel PP?
PostPosted: Wed Jul 21, 2010 9:58 pm
maybe even something aftermarket?
 Post subject: Re: anyone got a good flat flywheel PP?
PostPosted: Thu Jul 22, 2010 8:39 am
A few more details would help...not that I have one. All my flywheels are in cars (not entirely true, but close enough).
PostPosted: Thu Jul 22, 2010 9:54 am
Ahh, yes! So flat flywheel for an 8.5" clutch, to be used with my T5 swap. It's been ligthened around the outside edge. I am hoping to attach the lh 2.4 tone ring from an auto flex plate to this ligthened rim. (Not sure if it should be bolted or welded, gotta figure out what's a higher stress riser in the cast iron). And get it balanced and surfaced.
I think jordan has one for me so I should be good to go.
PostPosted: Thu Jul 22, 2010 10:02 am
So you're looking for a pressure plate, or flywheel? I have a flat flywheel still attached to my engine...Greg has my old PP (PRESSURE PLATE, you perverts) though.
PostPosted: Thu Jul 22, 2010 10:21 am
You said pee pee. I don't recall having your pressure plate though Athal. Craig?
PostPosted: Thu Jul 22, 2010 10:36 am
You're right Greg, I meant Craig. All you white people look the same to me.
PostPosted: Thu Jul 22, 2010 10:42 am
Should be good on both actually now! (Unless someone has a flat lh one for sale or a cheap 8.5" mustang clutch.
PostPosted: Thu Jul 22, 2010 2:43 pm
:lol:
PostPosted: Thu Jul 22, 2010 6:15 pm
A guy has a flat, lightened 2.4 flywheel for sale on T'Bricks...
PostPosted: Thu Jul 22, 2010 7:43 pm
Alex has the one I used in my 240, PP is worn a little but I think its still in good shape. It is a clutchnet unit with the organic disc which I thought worked very well. If you are interested let me know.
