It is currently Tue Mar 24, 2026 2:15 am
 Post subject: parting the GT, want anything before it goes to TB and ebay?
PostPosted: Sat Jul 31, 2010 6:22 pm
I'm not too serious about this, but I sort of want to get rid of the GT. I just spend so much time at work working on cars, that I just don't have the time or drive to finish this thing. I had planned on ordering all of Ben's suspension this past pay cheque, but dumping all the money didn't sit well with me. I think I actually hate spending money.
Anyways, I'd take around 3500 for it.
Car is an 80GT, was black, has roller paint job white.
Suspension
Coil overs, bilsteins, poly bushngs, IPD torque rods, ipd pan hard rod.
Have a brand new rack in the box sitting in the trunk.
Brakes- stock... But will come with Dales rear wilwood kit (calipers and rotors not included).
Engine- B23E, 405 head that I cleaned up, RSi NA cam, Stahl Header, Megasquirt MS3 V3. Innovative wide band died, but will come with it.
Tranny-M46, but OD doesn't disengage.
Rear end- 3.91 with a true track
RIms are milla miglia. tires are brand new Dunlop Direzza Star specs- beyond sticky!
If it doesn't sell, i'll finish it. Body is getting rusty, you'd have to look at it. Oh and the interior has Sparco Speed buckets, with Bens seat adapters.
 Post subject: Re: Feeler- my GT
PostPosted: Thu Aug 26, 2010 12:39 pm
Ok, decided I do want it gone. Gonna throw it up on Kijiji tonight probably.
PostPosted: Mon Aug 30, 2010 12:50 pm
PostPosted: Wed Sep 01, 2010 9:06 pm
PostPosted: Wed Sep 01, 2010 9:55 pm
Good-lord.
Can you post a picture?
PostPosted: Wed Sep 01, 2010 10:31 pm
I can do better, here is a link to my gallery.
http://www.calgaryvolvoclub.com/gallery/v/Jordan/242GT/
If you go up one folder, there are more pictures mixed in there also.
PostPosted: Wed Sep 01, 2010 10:38 pm
I'll add more to it.
It has upper and lower chassis braces. Sparco seats, group-a spoiler (not mounted). camber/caster plates. Uhh oh and also, it comes with a GM world class T5 transmission and JohnV's modified bellhousing. Will also throw in a Dell Laptop for tuning the Megasquirt.
I'm sure there is more, but I can't think of it. Car will need to be towed away I think, just because on the highway it would spin pretty high without the overdrive. I never really did much highway driving in it once I modified it, mainly city driving.
PostPosted: Tue Sep 07, 2010 5:59 pm
I'm going to part the car out this fall. Once I'm into the new house.
front springs eibach 8" 300lb 2.5" $75- on hold
bilsteins Front and rear $200 -on hold
poly bushings (front bushings) $50- on hold
camber plates $175-on hold
Upper chassis braces- Craving boost- $150
lower chassis- stock GT- 30
torque rods- 90- on hold
panhard rod- 80 - on hold
springs 11" barrel springs 200lb- 50- on hold
rack-350=sold
RSi cam- NA stage 1- 125
Megasquirt- relatively tuned for na, MS2 V3 with extra code 300 (425 with laptop and manifolds/injectors etc)-hold
header- stahl header- 200
mani-rail-distributor 50=hold
chev t5-sold
bellhousing-sold
pressure plate-tentitivley sold
rear end true track limited slip, 300- on hold
seats- 400 (have one sold if someone wants only 1) one has tiny cig burn hole)-on hold
seat brackets 60 each
group a spoiler 250-on hold
wideband I never got it to work- 50 bucks(innovative)
wheels/tires 16x7.5 mila miglia with dunlop direzza star specs 225-50-16, 5000km on them if that... offers- essentially sold
rear brake kit- wilwood kit from dale, 300?
Open to offers, if there is anything else from the car you want/ let me know, its got a crappy s80 fan hacked to fit in with temp probe etc, and a 405 head with new seals and shimmed for the cam, lapped valves, plugged pulseair holes. ok rad, etc etc...
 Post subject: Re: parting the GT, want anything before it goes to TB and e
PostPosted: Tue Sep 07, 2010 10:50 pm
would the lower chassis braces be a direct fit for my dl coupe?
Is the grille for sale?
Do you have a picture of the groupe a spoiler, or is that the spoiler that is currently mounted on the car?
1970 Mercedes 220D
1971 Daimler ds420
1977 Mercedes 230
1979 Mercedes 300TD
1993 Honda Del Sol Si
1994 Honda Civic dx hatch
2015 Mazda CX-5
2020 Hyundai Elantra manual
1982 240 DL coupe
PostPosted: Wed Sep 08, 2010 12:02 am
have you budged on the price for the suspension? and what were you asking for that other sparco?
PostPosted: Thu Sep 09, 2010 7:21 am
Paperjam- 575 without the upper and lower strut braces. Add another 125 if you want the Upper braces.
The second sparco- my roommate will pay 250 for the good seat, So the one with the little hole would be 150. I'll throw in the seat mount for another 50. That leaves me with one spare bottom mount seat bracket.
Unico- As far as I know, the braces will fit. I think all the holes are there for them, if not its 5 minutes with a drill.
Yes the grill/fog lights/swich would be for sale. The grill might be missing some tabs. 50 bucks?
I do have a picture of the spoiler.... This is the only one
PostPosted: Thu Sep 09, 2010 6:37 pm
ok, sign me up for the braces, the grille assembly put me as tenative, the spoiler im not sure. A little to much? Style that is...it is the leg that it is going on...lol..
are you around either early saturday morning or later sunday evening? Same with you Dale, still interested in that clock.
I won't take the grille, id love to have it but i do not have a flat hood or headlight assebly to go with it....and more than likely i never will...
1970 Mercedes 220D
1971 Daimler ds420
1977 Mercedes 230
1979 Mercedes 300TD
2015 Mazda CX-5
1982 240 DL coupe
PostPosted: Thu Sep 09, 2010 8:23 pm
ill buy the seat then, 575 is not in the budget untill at least a couple weeks, and there are still 1jz parts to buy first... ill get back to you on that.
PostPosted: Thu Sep 09, 2010 9:00 pm
Unico, i'm in Edmonton. You can have the headlight assemblies, and buckets, and the flat hood also, if you want. The hood is a little beat, but it will do for now.
Paperjam, Don't worry too much about time line, I probably won't start pulling it apart for 2 weeks. Once I've moved and settled in, then I'll strip it down.
PostPosted: Fri Sep 10, 2010 8:03 am
what kind of money are you asking for them?
Ill be in the edmonton area all weekend.
1970 Mercedes 220D
1971 Daimler ds420
1977 Mercedes 230
1979 Mercedes 300TD
2015 Mazda CX-5
1982 240 DL coupe
