It is currently Sun May 03, 2026 9:26 am
 Post subject: *EVENT* Spring cleaning, come get it.
PostPosted: Fri Apr 06, 2012 4:53 pm
I'm moving to Vancouver. Everything must go.
I have a whole bunch of random stuff not listed that's basically going to the dump if no one wants it. Relays, wiring, random interior pieces, a 740 M46 shifter, manual late 240 mirrors, intercoolers, hoses, and probably some extra tools. Make an offer on the stuff I've listed below, I'd rather not pack it out to the coast.
Just call or text, and come by to have a look any time. 403 seven oh one, 2228.
I'm leaving in early May, roughly around the 9th, so you have until then!
Everything was working when it was last removed/used. All prices DO NOT include shipping.
Two LH 2.2 007 AMMs. $30 ea
240 GT fog lights. $40
One lens busted, someone covered with reflective tape. Obviously at least one lens would have to be replaced to be functional, but the brackets are the tough to find part.
940 ECODE wipers $50
Bought from Mr. Borrie, but don't fit the 740 ecodes I have on my 940. Wiper arms need a re-finish, blades are old but you could probably cut some new blades and fit, and you need to sort out how to wire and plumb everything. Hmm, looks like the one wiper is missing the nut cap, if you're concerned about cosmetics.
740/940 rear brake calipers, one new $75, one rebuilt $50. if someone wants I can figure which is left and right, probably not worth shipping though. Both come with new pins and springs.
240 clock w/ harness $20
240 small ecode, passengers side. $50
The one that sort of survived when I rear ended someone. it's been repaired once, but it's far from perfect, though the glass and reflector are good. I hope someone can make it work, it would be a shame to toss it.
LH 2.2 Turbo computer. Stock 541 $50
740/940 Turbo K&N filter $40
Direct drop in replacement for stock airbox
240 3-gauge pod, with VDO boost gauge, 5 bar oil pressure and sender. $75
I may have the bracket for a third gauge somewhere.
NPR Intercooler $175
Still has the hoses Matt muscled on for me. I can take them off to save shipping space.
V-cam $100
Has some surface pitting and a few of the lobes are lightly scored, but nothing that should affect functionality. Tried it in my 940 but preferred my custom grind so this is collecting dust. I can take some better pictures if you really want it, just need to get the other camera with macro.
Lastly, K-jet main pump. Bosch. Only used about 1 year. $75.
 Post subject: Re: Spring cleaning, rare and fun parts 240/740/940
PostPosted: Fri Apr 13, 2012 6:34 pm
Didn't figure folks around here needed much, thought I'd give y'all a week before I post on Turbobricks and kijiji.
 Post subject: Re: *EVENT* Spring cleaning, come get it.
PostPosted: Tue Apr 24, 2012 8:24 pm
Bump, turned it into an event. See original post.
