It is currently Wed Jan 28, 2026 9:21 pm
 Post subject: I'm in purge mode
PostPosted: Tue May 07, 2013 7:56 am
Hi, all
Over the coming week or two I will be processing a number of items in my stash that will be for sale or for giveaway (which sometimes amounts to the same thing). I will post them up here first and then they go on Kijiji. At this point I don't have a complete list of items or prices but I have a start and that's, well, a start.
First off is obviously my 780. Currently on Kijiji for $3000 (EDIT - NOW $2500), I will sell to anyone on here for $2500. This is as low as I will go.
http://calgary.kijiji.ca/c-cars-vehicle ... Z486599049
I also have the following:
(pictures of the rest to come later)
- Powerstroke intercooler. This is the giant Ford F250 Powerstroke intercooler that you crazy kids want to install into your 240. $125
- Nissan UD intercooler. This was bought to run in my 740, a big heavy upgrade for the stock unit. A smaller core, similar surface area but better flow and all welded construction. $100
- Stock Volvo intercooler. $25
- Brand New T-04 turbo, in box. Never been run, and I’m not really sure what compressor it’s got but by measurements it’s somewhere between an S-3 and a V1/V2, which puts it comfortably into the 350hp range. The turbine is a .96 A/R “P” trim (I believe), which is obviously huge but you can get turbine housings for this wheel down to 0.50 A/R in either single or twin-scroll configuration. $400
- Holset HX-35W turbo. I’ve had this thing for 8 or 9 years, never once installed it. It’s super clean and has a modified wastegate flapper & discharge flange for added flow. It’s in great shape. $250
- Holset HY-35W turbo. I’ve had this thing for 5 or 6 years, never once installed it. $200
- Quite a few Garret T3 parts, donor turbos, etc.
- 740 Hydra wheels. Were used as winter wheels, these are rashed and nasty but are straight and round. $150 (once I remove the tires) (Sold)
- 740 brake/clutch pedal sets. One hydraulic, one cable, each $25. (Hydraulic sold)
That’s probably not all, but it’s a good start. PM me if you want anything or everything.
Matt
 Post subject: Re: I'm in purge mode
PostPosted: Wed May 08, 2013 9:59 am
Do you have a cpr for a b21ft and black interior carpet for the 240
PostPosted: Wed May 08, 2013 3:42 pm
I haven't had any 240 or K-jet stuff for a long while.
PostPosted: Thu May 09, 2013 9:43 am
I have a CPR for you. PM me for details.
PostPosted: Tue May 14, 2013 7:37 am
Bump - really? Nothing?
PostPosted: Tue May 14, 2013 8:02 am
Sorry Matt, if I could have used any of the turbo's you would have seen me at your door this weekend...
PostPosted: Tue May 14, 2013 3:16 pm
Well clearly I didn't need any of the turbos I own either, so what's stopping you?!?
PostPosted: Tue May 14, 2013 5:13 pm
They're all too big for my application?? I'm trying to restrain myself?? I really don't know?? :shrug:
PostPosted: Wed May 15, 2013 5:07 pm
Hi Matt,
Do you have pictures or dimensions on the UD intercooler? I googled it but came up with a couple different styles.
Thanks!
PostPosted: Tue May 21, 2013 8:51 am
Inside of nozzle to inside of nozzle:
Core width:
Overall height:
Thicknesses:
Overall shape:
Compared to the Powerstroke intercooler:
Powerstroke overall:
