It is currently Wed Apr 01, 2026 3:48 am
 Post subject: LF: Set of endlinks for my 7
PostPosted: Sun Aug 17, 2014 7:39 pm
Vmax 200mph w00t!
Hey all,
I'm in need of an endlink for my 780, but the other is fairly crusty so i thought i'd replace both.
Anyone have a set lying around? if not i'll probably go with FCP or something.
94' 944t "The Good One"
87' 780 5.0L V8
 Post subject: Re: LF: Set of endlinks for my 7
PostPosted: Mon Aug 18, 2014 7:29 am
Do you have the alloy control arms or the iron ones? Does the endlink bolt into the front of the arm, or does it pass thru it like on the swaybar end? I'm guessing the first style.
No, I don't have any. I switched to the alloy arms that take the kind of endlinks that you can replace at any speed shop, which came from my 745. Not sure what THEY came off, because I forget if I pulled them out of a JY to replace all the bushings with poly or not.
PostPosted: Mon Aug 18, 2014 2:54 pm
Vmax 200mph w00t!
It bolts to the front, as you said.
Truth be told I have not come across the latter in my 7 series travels.
87' 780 5.0L V8
