It is currently Tue May 05, 2026 6:34 am
 Post subject: WTB Garrett t3
PostPosted: Mon Jan 28, 2019 11:48 am
Looking for a t3 to upgrade my benz.
Anyone got a stock garrett, or even a t3-60 they're not using?
 Post subject: Re: WTB Garrett t3
PostPosted: Mon Jan 28, 2019 2:48 pm
I bought one off of you xx?? Years ago. Never did install it and have no plans for it. Gimme a bit to dig out of the shed and check, pretty sure it’s a t3.
PostPosted: Tue Jan 29, 2019 1:13 pm
Yup, it’s here! I bought it off you in 2012, I remember I ended up finding a useable td04 and installed that instead to avoid swapping lines etc.
PostPosted: Sun Feb 03, 2019 11:54 am
Cool!
Matt has one as well, but it's a bit of an unknown. Is the one you have a t3 60 with a 62(?)AR exhaust? No, it couldn't be, that went with my old engine...so its perhaps a smaller compressor?
In any case, I'm trying to figure out how easy a swap this is from the control side before I dive in. The stock turbo runs off a vacuum signal, so I need to figure out if I can simply swap wastegate actuators or need to retune the ecu.
PostPosted: Sun Feb 03, 2019 4:13 pm
It's a T3 60trim compressor in a 0.42a/r housing with a 0.63 a/r T3 exhaust.
I cut and pasted that from the PM you sent me when I bought it, I thought this came off your 242, but I could be misremembering that...
PostPosted: Mon Feb 04, 2019 10:03 am
IIRC that 60 trim 0.42 AR was from the 300ZX turbo I pulled. I had one from a 300 and one from a 280, I kept the 280 and I think I now remember giving that 300 to you, Athal.
PostPosted: Mon Feb 04, 2019 11:38 am
Yup, its a Nissan branded turbo.
PostPosted: Wed Feb 06, 2019 11:03 am
Am I reading it wrong, or is the t3-60 compressor map very close to the stock k14 turbo? In that case the only difference might be slightly slower spool for better top end with what I'm sure is a larger exhaust flow.
http://www.not2fast.com/turbo/maps/all.html
I still havent figured out how the control works either.
PostPosted: Wed Feb 06, 2019 3:16 pm
Using the bottom scale on the Triple-K map and converting it from kg/sec to lb/min, I would say that the Garrett is a bit stronger in the compressor section. Using the 2.0 pressure ratio line and the 70% efficiency curve, the Garrett spans about 13.5 to 27 lb/min while the K14 spans 10.5 to a bit under 24 lb/min. They're both good for over 230 hp here, with the Garrett being capable of about 270.
Of course, the K14 claims to have a better peak efficiency of 76% compared to 74%. In practice this makes very little difference.
As you correctly say, the bigger difference will probably be in the turbine section. If the .63 A/R turbine is significantly freer than the K14, you will indeed have lazier spool but much better top end. The surge line is a bit further to the right on the Garrett compressor so a bit lazier turbine is going to help here.
PostPosted: Mon Feb 11, 2019 3:30 pm
This may be the smartest way to go, certainly simplest.
https://www.ebay.co.uk/itm/NEW-K16-Turb ... 2201575238
Get the air a bit less heated but unless I can modify the exhaust at all might not actually gain that much
Users browsing this forum: No registered users and 18 guests
