It is currently Tue May 05, 2026 6:39 am
 Post subject: Problem found...
PostPosted: Thu May 25, 2006 5:55 pm
I did find my oil leak... :cry:
Matt, it's not that I don't like your mod (far from it!), but my turbo didn't like it at all. I checked the air hoses from the air filter to the turbo and from the turbo to the intercooler. There was a lot of oil in it. Looks like the seal of the turbo are not in good shape and it wasn't a smart idea to boost a 400k km turbo.
It still run, but for how long...
What's better: get a new turbo ($$$ but supposed to work for sure) or a rebuild kit (cheaper, but incertain results)
PostPosted: Thu May 25, 2006 8:56 pm
get a holset, sways, spring,s shocks, bushing, camshaft, strip the car down
there's an idea for you anyway
PostPosted: Thu May 25, 2006 9:25 pm
What's a holset?
PostPosted: Thu May 25, 2006 9:49 pm
the big turbo looking thing :wink:
PostPosted: Thu May 25, 2006 9:56 pm
Just a small boost is already an addictive drug. A big boost might lead to an overdose! :lol:
PostPosted: Fri May 26, 2006 7:03 am
All turbos leak. All of them. Most of them don't really have "seals" so much as they try to get all the oil to shed off the turbine shaft before it exits the bearing cartridge. Added vacuum in the intake system, like if you've got a slightly dirty air filter and you start raising the boost, can draw out some oil and cause it to collect in the compressor discharge pipes and the intercooler. But even a stock, brand new turbo leaks some oil if it's got dynamic oil seals.
PostPosted: Fri May 26, 2006 7:34 am
It's not the first time that I check the turbo, but it's the first time that I see so much oil.
