It is currently Tue May 05, 2026 3:09 pm
 Post subject: Electric fan
PostPosted: Fri Mar 21, 2008 8:55 pm
Did any of the 200/700/900 cars come with an electric radiator fan? I was thinking of installing one on my radiator inplace of the one on my water pump. I am asking this because I was hoping for a bolt-on solution to this.
PostPosted: Sat Mar 22, 2008 8:40 am
I've never seen one...but don't let that tid-bit of non-information discourage you. Both Dale and I are running e-fans in our 122's. I got my fan from a Mercedes in the JY (Bosch 16" for $15) and put it in with an e-fan install kit from Summit Racing for another $35. The kit included the relay, wiring, and temperature sensor (I added that to one of the external coolant lines.). Works like a charm (off at 175 on at 185 degrees F).
Makes things under the hood a little cleaner and scares the crap out of people when the grandpa car fan kicks in (it moves a lot of air). I'm sure it saves me a HP or two, which is more relevant on my car than any of the others on this board (I've got the least HP). You could also buy a Flex-a-Lite or other fan, just get one with a temperature sensor (thermister) rather than the bulb that you stuff into a rad hose.
PostPosted: Sat Mar 22, 2008 8:50 am
Alot of us (well, me at least) use GM 3.8(?) fans, wired to a relay controlled by a switch in the upper rad hose.
That being said, '94 and '95 940s used 2-stage electric fans, and came with slightly larger rads (that still fit in a 240 i think).
PostPosted: Sat Mar 22, 2008 11:45 am
I guess I will have to make a trip to Pick N Pull. I think I saw a couple of mercedes there whan I was there last. The Gm section should have plenty of 3.8's.
PostPosted: Sat Mar 22, 2008 12:05 pm
Yup, just cut off two tabs on the GM units and put some long screws through the corners and they fit a 240 rad almost perfectly.
PostPosted: Sat Mar 22, 2008 4:28 pm
I know that on the latest 940, there was an electric fan.
But no idea if you can get one like that here.
PostPosted: Sun Mar 23, 2008 3:30 pm
You should really read previous posts Steph :P
PostPosted: Sun Mar 23, 2008 5:00 pm
940 had factory fan and thermo-switch in rad. Im using a late 740 or early 940 rad in my volvo with a built in thermoswitch and a taurus fan.
PostPosted: Sun Mar 23, 2008 7:14 pm
The 92 and later 7/9 and 850 use similar fans, though thee 7/9 fan and 850 fan have a different shroud. The 92+ fan is coontrolled by the ECU and comes on at ~200F or something obscene. Every e-fan car I've pulled a head off of shows signs of getting significantly warmer than the old clutch fan cars.
Volvo also put a much better alt in the 92 and newer cars that lasts much longer under continuous heavy load. The plastic fan with a good clutch is my preference over the electric. I can't feel any significant loss in power with the clutch fan or rev response with it unlocked, so it doesn't bother me.
PostPosted: Sun Mar 23, 2008 7:26 pm
I like my fan. When it's hot, it sounds like I have a big mean engine! :lol:
PostPosted: Sun Mar 23, 2008 7:29 pm
I like my fan...it comes on at completely random times when the car isnt running!
PostPosted: Wed Mar 26, 2008 6:23 pm
I used a 2-speed 16" fan from a full sized mid 90s FWD GM car (a Buick Park Avenue I think) for my e-fan conversion in the 240. I just went out and measured the rad on my '95 940 and those GM e-fans should fit nicely in a 900/700.
To do the conversion I also used a couple 40 amp relays and a thermal switch out of a mid to late 90s VW Golf (they use 2 speed fans) and a rad hose thermal switch adaptor out of a SAAB 900.
You can also use the smaller 1 speed fans out of the FWD GMs with the 3.8 litre engines but I prefer the 2 speed fan system I used.
I've found that the e-fan hardly ever kicks on in the 240 even in stop and go traffic in the summer time which goes to show those stock clutch fans are just a total waste of power and gas about 98% of the time.
Here's a pic of the 2 speed 16" e-fan in my 240:
