It is currently Sun Mar 29, 2026 9:27 am
 Post subject: Painted rims?
PostPosted: Mon Dec 15, 2008 3:37 pm
I have an '87 740 and a nice set of dracos with winter tires.
I've been reading up on how to paint them. So now I'm just trying to decide on a color. My car is gold (I believe the paint code is 400-1) so I wasn't thinking I would piaint the rims gold. I was thinking of maybe gun metal color or a very dark, almost reddish brown color.
If you've pained your rims or have opinions on a good color choice before I "pull the trigger" I would like to hear them before I make a bad choice and have to start again.
Thanks
Doug
PostPosted: Mon Dec 15, 2008 3:48 pm
Drive by my place and have a look at the 14's I painted up for the 242 a number of years back. Gunmetal grey wheel paint from crappy tire I think. Has held up pretty well, certainly not perfect, but then it's far from a perfect job. Like all painting, the proof is in the prep. I think I bead blasted them first, which really helps clean them off.
PostPosted: Mon Dec 15, 2008 4:30 pm
did mine with the dupi-color that crappy tire sells, just make sure your prep is good and you will be fine.
PostPosted: Mon Dec 15, 2008 11:17 pm
the Idea was I would take them to my friends heated garage pressure wash them using some kind of rim soap to remove dirt and grime. then power sand them and then paint and polish.
does that sound right?
Doug
PostPosted: Tue Dec 16, 2008 1:13 am
I would try a wheel acid for the caked on brake dust, the wheels aren't chrome so you wont have any problem with the finish being taken off.
PostPosted: Tue Dec 16, 2008 12:20 pm
where do I get wheel acid?
and how do I use it?
Doug
PostPosted: Tue Dec 16, 2008 12:28 pm
Easy does it there chemical man...some chemicals don't react very well to clear coat. Check first. Simple Green will remove all sorts of nasty stuff finished off with some wax and grease remover. Try to avoid Spray Nine or lacquer thinner they are not all that nice to most finishes.
PostPosted: Tue Dec 16, 2008 12:49 pm
would a pressure washer, rim soap, and a little elbow grease. do the trick? or would I need to use something harsher?
Doug
PostPosted: Tue Dec 16, 2008 4:18 pm
Neither is bead blasting. I thought the original question was about painting the rims, not trying to preserve the original finish?
PostPosted: Tue Dec 16, 2008 6:18 pm
thats right. so how should I clean them?
chemicals or no chemicals? that is the question...
So back to the original question... color?
Doug
PostPosted: Tue Dec 16, 2008 6:33 pm
You want the original finish to remain intact...it can be softened by some chemicals - that was my point. If you're going to give your wheels a quick spray paint job (rattle can assumed), then go to your local paint dealer and pick up some red 3M scuff pads and have at it. Clean with wax and grease remover first, then scuff, then clean with W&G and paint. Try to have both the wheels and the paint somewhat above freezing for this to work.
PostPosted: Tue Dec 16, 2008 7:00 pm
Our chemicals are from Chemfax, I dont think they deal with the public.
PostPosted: Tue Dec 16, 2008 8:09 pm
thanks 122_Canuck that helps alot. the plan like I said was actually to do this all in my friends heated garage.
the two colors that i've narrowed it down to are:
Duplicolor - HWP105 Bronze
or
Duplicolor - HWP102 Graphite
Opinions please
Doug
PostPosted: Tue Dec 16, 2008 8:31 pm
We all like a pole...I would prefer the bronze over the graphite. Black wheels and black tires in a dark wheel makes the whole wheel disappear. Bronze or just straight silver is fine.
PostPosted: Tue Dec 16, 2008 9:06 pm
bronze, sorry dont have a better pic at the moment.
