 Post subject: VOLVO 740 NO START
PostPosted: Mon Nov 25, 2013 6:46 pm
Hey guys.
i just bought a 1991 740 Turbo intercooled. It turns over but will not start....
the fuel pump under the seat(this is what the guy i bought it from says) Has been replaced with one from PYP. Whats some possible issues...
 Post subject: Re: VOLVO 740 NO START
PostPosted: Mon Nov 25, 2013 7:37 pm
Could be a number of things. Does it have spark? Is the pump actually pumping fuel? Crank position sensor? Clean ground connections in the engine bay. Start with the ground posts on the inner fender on the driver's side by the headlight. Make sure the ignition powerstage mounted to the inner fender is properly grounded.
PostPosted: Mon Nov 25, 2013 10:21 pm
How full is the tank? ie: If the intank pump is dead (might have been what killed the main pump) may not be getting fuel to the main pump. Take the oil fill cap off and ensure the cam is turning ie: broken timing belt. Check the infamous Radio Noise Suppression relay, located on the DS shock tower. Use a jumper to test, not another relay.
PostPosted: Tue Nov 26, 2013 8:48 am
Thanks guys,
all these look like good things to check!
Heres a pic of my 245 pro)ject.
All it needs is clearcoat(will modify the fender colors) and moldings!
