It is currently Thu May 07, 2026 3:38 am
 Post subject: Any point to this...???
PostPosted: Thu Sep 07, 2006 11:31 pm
http://cgi.ebay.ca/Volvo-Header-242-GT- ... dZViewItem
a header fora B21F??? is there really any point?
Ian, Dale, Matt, or Athal...got some insight into this? teach me
PostPosted: Fri Sep 08, 2006 7:07 am
Why do you think there's no point to a header on a B21?
PostPosted: Fri Sep 08, 2006 7:45 am
Verr nace... :wink:
PostPosted: Fri Sep 08, 2006 7:53 am
I'm not sure what you're askin Vik?
Thats probably a nice 5-7 hp across the board right there ...
I'd actually ask what the point of a header is on a turbo car ... Yes, I know, better spool, less back pressure - etc - but ... well, the reasons seem more pertinent on an N/A motor
PostPosted: Fri Sep 08, 2006 11:35 am
well for a motor like your's/Ian's...i could see it...because they already make a lot of power
but the B21F makes like what, 100hp at the crank? how much could you get out of a B21F with say and intake/exhaust/header/camshaft....like 110hp??? doesn't seem worth it to me
that's what i am asking...is it really worth the money
PostPosted: Fri Sep 08, 2006 1:32 pm
Realistically, the power potential is limited by head flow, but look at the ITB cars to see what a "stock" NA OHC Volvo engine can make. To do that you need all your tricks.
Still, there's a reason why the headers are $600 USD. They're not terribly popular, the OEM exhaust manifold/downpipe is quite good, and you're not talking about too much of a power increase.
You're not going to gain 50 hp from adding a header alone, but adding a header will allow you to take full advantage of a set of Weber/Mikuni carbs and a big cam.
You didn't originally ask if they were worth the money, you asked if there was a point.
PostPosted: Fri Sep 08, 2006 4:03 pm
no that's not what i asked but it's what i meant, can't you read my mind yet?
:P
another question, has anyone out there built up a B21F a considerable amount to make you say "wow, that's cool" and produce some good numbers?
PostPosted: Fri Sep 08, 2006 4:36 pm
any engine can make some fun numbers with headwork, compression, full on balanced bottom end, lots of revs, and fancy intake/exhaust :)
PostPosted: Fri Sep 08, 2006 6:00 pm
I megasquirted my B21F, and it picked right up over the K-jet. Had a K cam in it (not sure that's the best choice) and a 2.5" exhaust, and it would run those B230F 17#/hr injectors to 100% duty (supposedly good for 125 hp) and I ended up installing B230FT injectors and was tuning them in before I spun a rod bearing.
No question in my mind that a B21F can make decent power - say, over 140 with just bolt-ons. Of course, a B23E longblock would swap right in, get you 10% more displacement and higher compression, plus better head flow, and theoretically starts out at 140 hp. Add MS, a good cam and a decent exhaust, and I bet 160-170 is within reach without head mods. Big valves, porting, and a little more compression and 180-190 is within reason, provided you can keep it spinning above 7000. Full race (8000+, fully built, 12:1 compression, huge cam, well developed head) and you'd get over 200 I'm certain.
PostPosted: Fri Sep 08, 2006 11:02 pm
You not happy that a certain 122 was pulling away from you last night? :wink:
PostPosted: Sat Sep 09, 2006 10:31 am
hahaha that's rich! :lol:
no that's not the problem, i was just curious...next year after the 760 is running i plan to give the GT an overhaul of suspension and front end/brake work
i was just thinking if it's worth it to tune a B21F or just leave it alone for a bit and have a solid lil beater motor 8)
PostPosted: Sat Sep 09, 2006 10:34 am
:lol: :lol:
What Matt was describing above was at one time my goal for my wagon. I really enjoyed my b21f with k-cam and 2 1/4" exhaust. It was good to a point, and pulled not too bad considering how it was stock. But to think about a properly built b23e is pretty exciting. Funny thing is, while I've seen/heard about a lot of worked b20's, I haven't heard about a lot of done up b23e's. They would truely haul, and make a lot of nice noise. I even remember someone in Sweden selling a different computer for it....it just said "160hp." Not sure how that would happen, but interesting.
I eventually opted out of such a build simply because of the investment....a lota money considering how cheap the turbo swap was....
PostPosted: Sat Sep 09, 2006 10:38 am
Vik, I'd change the cam and exhaust, and be done with it. There's not much to "tune" unless you tear it apart and go to a standalone. Considering you already have a project car, I'm guessing you'd be satisfied with a few bolt-ons?
PostPosted: Sat Sep 09, 2006 12:10 pm
i already have done up an exhaust, put in that K&N drop in filter, drilled out a lot of the airbox, (it's basically a frame to hold the airfilter now :lol: ) and thte next thing i was thinking of doing was the K cam, speaking with Athal one night here...other than that i don't plan to do much more to it cept for some springs/shocks/brakes...you know...so it can handle how i drive it :twisted:
PostPosted: Sat Sep 09, 2006 2:31 pm
Sounds good! Glad that K&N worked for 'ya!
