It is currently Tue May 05, 2026 8:41 am
 Post subject: wheel size question
PostPosted: Sun Sep 10, 2006 4:28 pm
what size are corona's? 14" i think and what width?
also any other 14" volvo wheels around besides the "GT" rims and steelies?
PostPosted: Sun Sep 10, 2006 6:00 pm
Newb.
http://www.forums.turbobricks.com/showt ... hp?t=72501
PostPosted: Sun Sep 10, 2006 11:32 pm
no yes i saw that...thus my post here....thanks matt...however the sizes of the wheels weren't written, at least not the 14" wheels
newb :P
PostPosted: Mon Sep 11, 2006 7:44 am
Coronas are 14x5, I believe, same as GT wheels. Might be 5.5, I'm not sure. There's also a 14" multi-x, the 700 hubcap-style alloy, etc. 14" wheels are the least common for Volvo because they were only ever spec'd on 200s and early 700s. Many of them won't fit over 140 rear brakes (a fraction of an inch larger than 200-700-900 rears)
PostPosted: Mon Sep 11, 2006 11:53 am
ok cool yeah the GT wheels are 5.5...guess i'll have to hit PYP and just keep checking stuff out
looking to get a set of 165/65/14 Hakka 2's or the new Hakka 4's
PostPosted: Mon Sep 11, 2006 12:11 pm
165/65???
PostPosted: Mon Sep 11, 2006 12:51 pm
I've got a set of steelies I need to get rid of....you want 'em?
Coronas are crap.
PostPosted: Mon Sep 11, 2006 2:49 pm
I'm sure (I hope) he meant 185. and 65 will be a bit undersized, 70 is the "proper" size. all things being equal, the 70's might be cheaper. handling will suck no matter what.
I'll be shopping for WR's with how little snow we get.
PostPosted: Mon Sep 11, 2006 3:25 pm
I hope he meant 165/85.
PostPosted: Mon Sep 11, 2006 8:49 pm
well i was thinking for a tire that i can TSD rally/winter autoX in...i will be running 195/60/14 for regular use
EDIT: should have mentioned that, these tires wouldn't be for daily use :oops:
but for racing, skinny and low profile seems to me to make sense to me, no?
PostPosted: Mon Sep 11, 2006 9:33 pm
the skinnier the better.
PostPosted: Tue Sep 12, 2006 7:12 am
On ice you want a very compliant skinny tire, but on gravel you need something with a stiff sidewall and skinny isn't as important. Gravel rallye tires have 1" thick sidewalls and aren't really skinny at all.
Edit - and 195/60-14 for daily winter use? What's wrong with a little sidewall and ground clearance? 185/70 or even a 185/75 is what I'd use for that car in the winter. Leave the low-pro for the summer.
PostPosted: Tue Sep 12, 2006 8:23 am
I disagree,
in the thick and deep gravel at the Winter-X parking lot, the skinnier tires have always helped me. fatter tires like 195+ made me skid across things as opposed to digging in and turning.
And sidewall/ground clearance is great, Vik, you don't need low pro - just up the tirepressure a bit :)
PostPosted: Tue Sep 12, 2006 11:34 am
it's what came on the GT rims when i bought the car...and they are pretty decent yoko winters...dont want to bother with another set for "daily" use yet
for a winter autoX where there isn't any snow i will be using whatever set of BFG's i have downstairs...i don't think i'll spring for a set of those gravel tires quite yet, but for the snow and ice on a TSD type deal...then i would like to have something better than what i have
