It is currently Mon May 04, 2026 8:18 pm
Post a new topicPost a reply Page 1 of 2   [ 19 posts ]
 Post subject: Carb to FI?
PostPosted: Mon Mar 19, 2007 5:14 pm
Vmax 200mph w00t!
Ok, so this isnt about Volvo's. Sorry but I dont have one anymore.
I'm swaping engines in my truck to a 240sx and I have some questions and I know you guys will know the answers.
Also I will be running all aftermarket gauges (electronic) and heater, so those wires can get ditched.
I need to know if I need to keep any of the wiring off the engine thats currently in there?
Or do the ECU's for FI just run thier own little game and the body wiring (like lights and well, lights) run its own show?
Anyways, I know its a nissan and not a volvo but any help would be great!
Ohh and no, I dont want to megasquirt it! :P
PostPosted: Mon Mar 19, 2007 9:56 pm
Usually the engine does it's own thing, but depending on the year of the car you'll be pulling the engine and harness from, it might have other sensors or controls that the engine ECU is trying to control. If the donor is 96 or up, you'll have all sorts of sensors for things like EVAP, vehicle speed sensor, and the ECU will be trying to control the gauges, transmission (if applicable) EGR, etc. If it's older than '96, especially if it's older than '94, you'll have a better chance of turning the ECU into a standalone, and having it fairly seamlessly control the engine no matter what chassis it's in.
PostPosted: Mon Mar 19, 2007 11:29 pm
im not sure about nissan but like he said its pretty much independant on the earlier cars.
On my mr2 i kept the stock engine harness from the 3sgte and just modified the original body harness connector to make it plug in like stock. You will have to splice some wires but it really not that hard on older models.
PostPosted: Fri Mar 23, 2007 6:50 pm
Vmax 200mph w00t!
Awsome, thanks guys!
Trying to find a decent KA motor is tough though. Might have to go the JDM route and get a 1.8 turbo engine.
200hp in a little Datsun.... Hello fun! :twisted:
PostPosted: Sat Mar 24, 2007 7:15 pm
hey if you need a motor i can get deals at jdm source i bought my gen 3 from them and a couple other motors...
PostPosted: Sat Mar 24, 2007 11:11 pm
Vmax 200mph w00t!
Sweet thanks man!
I just looked at a few more pics and the CA18 and SR20 are front sumps and I need a rear sump, so the KA doesnt work either.
Time to start hunting!
This sucks balls.
PostPosted: Sat Mar 24, 2007 11:41 pm
350 time I guess....
PostPosted: Sun Mar 25, 2007 12:21 am
this is for your minitruck right?
why do you need a rear sump?
PostPosted: Sun Mar 25, 2007 12:22 am
and booooo to a 350, you need turbo :)
PostPosted: Sun Mar 25, 2007 2:06 am
we just have to put out every available option...comon here! Agreed on something turbo though
PostPosted: Sun Mar 25, 2007 7:15 am
Redblock!
PostPosted: Sun Mar 25, 2007 12:49 pm
Vmax 200mph w00t!
Ya its for my truck.
I need a rear sump because the steering linkage goes under the front of the oil pan.
I could put in a rack and pinion but I dont want to reinvent the wheel on this thing!
PostPosted: Sun Mar 25, 2007 1:39 pm
Rear sump you say?
... Smallblock... With a turbo? :)
PostPosted: Sun Mar 25, 2007 6:53 pm
put a new steering rack in its super easy if you can weld and measure... Just make sure you get one that doesn't have power and you are good to go. since you are swapping a motor anyways its only a couple hours extra work to get rack and pinion in there... all the guys with early toyotas convert to rack and pinion this way.
you will need to weld up engine mount anyways so IMO i would just do it all at once so you are happy with it.
PostPosted: Sun Mar 25, 2007 8:21 pm
Vmax 200mph w00t!
Ya, I might have to do that.
Or I have dual Dellorto carbs I can put on it. They would suck to tune but would look really bitchn'!
As for the 350, way to big for that truck. I'm trying to fit the stock hood, and at 24" to the top of it, its alittle tight!
