It is currently Wed Mar 18, 2026 4:37 am
Post a new topicPost a reply Page 5 of 5   [ 70 posts ]
Go to page Previous  1, 2, 3, 4, 5
PostPosted: Mon Oct 01, 2007 12:46 am
Yup, it was 50.
Glad you guys had a good time.
See you all soon.
PostPosted: Mon Oct 01, 2007 7:26 am
you comin out on wednesday razalicious?
PostPosted: Mon Oct 01, 2007 8:29 am
Thanks Raz! Ya needless to say I was very pleased:)
ps. no can be there wednesday.
Last edited by swedishmeatball on Mon Oct 01, 2007 10:58 am, edited 1 time in total.
PostPosted: Mon Oct 01, 2007 10:16 am
Wednesday @ 8:30? Sure thing. I can be there.
Congrats on the numbers everyone, very nice :)
PostPosted: Mon Oct 01, 2007 6:09 pm
aah! you make me so sad :(
less eye candy for me on wednesday. oh well, at least andy's still goin ;) and raz...but raz arent you still taken? you're not allowed to be oogled
PostPosted: Mon Oct 01, 2007 7:23 pm
you can oogle, just don't touch too much. GF says so.
PostPosted: Mon Oct 01, 2007 7:24 pm
lol i still would rather not oogle the taken lads. I have SOME sense of honour.
PostPosted: Mon Oct 01, 2007 7:53 pm
well hey, come on guys...Jenn might be showing up....
AND she's got motor related questions that I'm only half ass guessing!
PostPosted: Fri Oct 12, 2007 12:35 pm
Just a confirmation of the valve float I was experiencing. From AFR (Air Flow Research):
"Note:
Hydraulic roller cams typically experience valve float at 5800-6000 rpm because of their fast ramp rates. AFR suggests you upgrade your springs to AFR part #8032, 1.530 O.D. with higher spring pressures to reduce chances of valve float associated with rpm’s 6000 or higher."
Crane cam also documents a lot of problems with pushrod flex with upgraded valvetrains. I have fairly stout pushrods but I need to check exactly what they are, this could be the solutions and an easy fix
My valve springs are upgraded considerably but I am also running much larger 7/16" roller rockers = strong & reliable but a bit heavier.
Solution:
Redline now set at 5800 :D
PostPosted: Fri Oct 12, 2007 1:32 pm
Temporary solution, right Ian? Would be a shame to not rev that thing to it's potential...
Edit - even though RPM stands for Ruins People's Motors.
Edit 2 - and the 7/16" portion of the rocker has nothing to do with rev range, right? It's more the heavy 2.02 valves and the 1.7:1 rockers.
