It is currently Mon Mar 02, 2026 3:46 pm
 Post subject: '89 B230FT
PostPosted: Sat Sep 06, 2008 1:25 pm
Come & get it. 300,000 kms on it, comes fairly bare.
PostPosted: Sat Sep 06, 2008 11:32 pm
dibs.
call me anytime for immediate same day pick up! :-D
(403) 890-TECH
:D
- Raz
PostPosted: Sun Sep 07, 2008 3:39 pm
RaZ wrote:
dibs.
(403) 890-TECH
:D
- Raz
Geeze Raz, when are you going to swing by and pick up that AW71 you said you'd take off my hands several months ago ? I want it gone yesterday.
PostPosted: Mon Sep 08, 2008 1:27 am
I'll make an effort to pick up said AW and said B230FT this week, room mate has truck - makes life easier.
PostPosted: Mon Sep 08, 2008 9:03 am
Is there a turbo on said engine?
If so, Raz, are you gonna be needing it?
Mine is spewing oil all over my engine bay, so I think its time to swap.
PostPosted: Mon Sep 08, 2008 11:14 am
There was a turbo on this engine, but there is no more. It's the crappy little TD05H-12B thing that came stock on the car, and the turbine housing is showing cracks all around the spool.
If your turbo is spewing oil, check your crankcase ventilation system. There must be ZERO backpressure inside the crankcase. Additionally, the oil drain from the turbo must flow evenly and smoothly downhill, but I think you've got a B21FT and all associated plumbing on there, so it should be as the factory set it.
PostPosted: Mon Sep 08, 2008 4:55 pm
Gotcha.
I've got an F block, so I've done the +T thing like so...
Its been drilled at an angle, but there's still a slight uphill about 1.5" long. Its never spewed before, so I'm thinking that's not it. I'll check the crankcase thing though. Thanks Matt.
