It is currently Mon May 04, 2026 6:07 am
Post a new topicPost a reply Page 6 of 7   [ 101 posts ]
Go to page Previous  1 ... 3, 4, 5, 6, 7  Next
PostPosted: Fri Jan 30, 2009 5:25 pm
bah. how else am i gonna learn?
oh well. See y'all tomorrow!
PostPosted: Fri Jan 30, 2009 6:08 pm
pro_star wrote:
Kat stay the hell away from under the hood?
This...
Unless you know what you're looking for or listening for, you will accomplish nothing...
Except to worry yourself into a tizzy.
PostPosted: Fri Jan 30, 2009 6:15 pm
Point taken. All i can do is sit back and enjoy her while the weather is nice then limp her in and get a rental when the weather turns
PostPosted: Sat Feb 07, 2009 5:01 am
cylinder 4 again !!
lets switch the injectors over from 4 to 3 and see if the fault changes.
did you clear the fault again???
Bert & Jacks Auto Service
129 17th ave S.E
228-7078
Paul
PostPosted: Sat Feb 07, 2009 8:45 am
Kat's coming over to try my oil flush idea today, Paul - I can swap injectors 'round and let it ride. Hopefully it gets cold enough to either do it on #3 or not do it at all.
My wild hair is that she's got 330,000 km of organic oil flowing through Viv's veins, changed at 7000 km intervals. There could be a good amount of sludge and slime in there, which COULD be fouling a lifter and hanging a valve open when it gets cold. Earlier B5234 engines suffered from hanging lifters known as Lawnmower Syndrome, so I figure later cars could be succeptable to the same thing given the right conditions. Even if this is not the problem, it can't hurt to flush the crankcase... I believe we're flushing the tranny at the same time, just for good measure.
Ian's bet is on injectors, and I think my idea IS a bit far-fetched, but if you have changed plugs and checked wires/cap/rotor, there isn't much left.
PostPosted: Sat Feb 07, 2009 9:34 am
Your idea is one that should be done anyway though Matt so that will be all good. I plan on doing lots of mad errands around town but should be at your place round two thirty give me a call if we need to fudge the time or if you do need anything from out and about lol. Odd thought - I had no mis fires while running the injector cleaner but got one the other night when i was not - did not have time to stop by cdn tire this week
PostPosted: Sat Feb 07, 2009 10:28 am
only problem with an engine flush is Christine is high mileage and may start to burn oil and lots of it.
swap injectors would be a good route to go.
Paul
129 17th ave S.E
228-7078
Paul
PostPosted: Sat Feb 07, 2009 11:09 am
Why would she start burning oil? Are you thinking the gunk could be sealing a few leaks?
PostPosted: Sat Feb 07, 2009 12:07 pm
because you can wash the carbon out behind the piston rings and now you have a loose cylinder.
129 17th ave S.E
228-7078
Paul
PostPosted: Sat Feb 07, 2009 12:46 pm
touche.
PostPosted: Sat Feb 07, 2009 9:21 pm
So after running crank case cleaner through and sea foam plus doing some chinese water torture - have your code reader handy lol - and swappin injectors on four and five we found something interesting - which could be part of my issue. VACUUM LEAK FROM HELL its under the cyl furthest to the pass side - paul its a pain to get to but i am sure your lads are up to a challenge if its ok i will bring her in monday. No sign of blue smoke yet either ;-)
PostPosted: Sat Feb 07, 2009 10:37 pm
Yeah, it's the vacuum elbow at the #1 side of the intake manifold, I presume to go to the PCV system 'cause it runs underneath.
#4 & 5 injectors have been swapped, so if the misfire moves around we'll know what's happened.
PostPosted: Sun Feb 08, 2009 8:59 am
i know that vacumn line well. :cry:
129 17th ave S.E
228-7078
Paul
PostPosted: Sun Feb 08, 2009 9:59 am
Yeah it seems like it will be a royal pain to get at.
PostPosted: Sun Feb 08, 2009 10:07 am
Is that the one that you have to remove the intake manifold to get at?
If it is it would be worth while to replace the entire PCV breather system.
http://www.fcpgroton.com/product-exec/p ... gory_id/63
If it is not, Kat forget I said anything :lol:
