It is currently Mon May 04, 2026 4:06 am
 Post subject: Fuel Pumps
PostPosted: Mon Feb 23, 2009 11:36 am
Any differences between the kjet and Lh main fuel pumps? or are they identical... my pump is complaining quite a bit still, so I figure I can just slap the 242's pump over for the time being, as I will likely go with a different setup eg walbro etc..
PostPosted: Mon Feb 23, 2009 12:14 pm
i think you said you checked the electrical at the pump already right?
kjet pump is rated for much higher pressure, generally considered an upgrade from the standard LH pump. THat's what I'm using. I don't think either is a limitation unless you're pushing 250HP+.
PostPosted: Mon Feb 23, 2009 7:35 pm
Ok great,
It runs, just noisy, so im going to replace the filter and see if that helps... then ill switch the pump
PostPosted: Tue Feb 24, 2009 8:20 pm
So I figured I would just switch the pump while I had everything unhooked. Lo and behold I snapped the yellow terminal... FAWK!!!!
does anyone have a known good k-jet fuel pump that they are willing to part with? cause I really am too lazy to go to pnp to pull one on the chance that its dead... which it likely.
Anyone?
 Post subject: Re: Fuel Pumps
PostPosted: Fri Feb 27, 2009 5:52 pm
Ok.
so I got a new pump from the yard (from a cam pillaged glt... hmmm)
and I got my afr guage all sorted out.
problem is now that I run richer than hell (all sorts of bogging) untill the o2 sensor comes up to temp, and my readings begin to look normal...
could this be a dead fpr? I know I need to install the computers and new fpr and such. but I was just wanting some insight into why this is happening...
thanks guys.
PostPosted: Fri Feb 27, 2009 6:28 pm
i've got a spare turbo ecu if you want to try it.
obviously if you don't have your fuel and spark set up properly chances are the car won't run properly. This is LH 2.2? Have you checked/adjusted the idle mixture?
PostPosted: Sat Feb 28, 2009 1:04 pm
yeah, I have the ecu and injectors, but im waiting STILL on the fpr / rail and the ezk box....
and yes this is lh 2.2
