It is currently Thu Jan 22, 2026 10:47 am
Post a new topicPost a reply Page 2 of 4   [ 48 posts ]
 Post subject: Re: Poly Bushings
PostPosted: Sun Apr 19, 2009 6:12 pm
when are you placing the order?
PostPosted: Sun Apr 19, 2009 6:27 pm
If you can get motor mounts ill definately be in on this order.
PostPosted: Sun Apr 19, 2009 6:35 pm
oh hells yea, i'd love motor mounts. rocking two ratchet straps right now... lololol
PostPosted: Sun Apr 19, 2009 6:54 pm
No motor mounts guys. Get those from the boys at RSI...
PostPosted: Sun Apr 19, 2009 7:14 pm
cant pay the rsi guys in cash. i have cash, no plastic of any sort.
PostPosted: Mon Apr 20, 2009 5:23 pm
Right, so here's what I'd like:
SPF0524K - lower endlink bushings, 1 kit
SPF1312K - lower rear trailing arm bushings, 1 kit
Lemme know price once you know.
PostPosted: Mon Apr 20, 2009 5:53 pm
I can grab you some when I'm down there next month. They're $85 US...
PostPosted: Mon Apr 20, 2009 6:02 pm
SPF0637K $38
SPF0638K $57
SPF0639K $35
SPF0524K (sway bars) $19
SPF2092B-4K (sway bars) $9
SPF0521-_ _K (sway bars - need size) $16
SPF1312K $79
Again, I should be able to do these prices in Cdn$...
PostPosted: Mon Apr 20, 2009 7:57 pm
Sounds good. Count me in for the above two kits I mentioned. Let me know when you need the money.
PostPosted: Mon Apr 20, 2009 8:59 pm
So i'll jump on here instead of pm.
I need :
SPF0637K
SPF0638K
SPF0524K
SPF2092B-4K
SPF0521-__K Will measure the bar tomorrow (im guessing 19 though)
SPF0522K
SPF0639K
SPF1312K
And im not sure which of the trailing arm upper bushings I would need, would anyone be able to offer some insight on that?
PostPosted: Mon Apr 20, 2009 10:22 pm
More than likely the 0727 bushings. I'm pretty sure your car won't have the earlier hourglass-style torque rods...
And just so there's no confusion, the SPF0524 is the lower endlink bushing. The SPF2092BK is the upper endlink bushings. There is also an SPF2755 (I think) that is also an upper endlink bushing but is almost twice the diameter of the 2092 bushing. I had some Swedes order some of those a long time ago. The 0524 bushing has never been available although perhaps it is now...
PostPosted: Mon Apr 20, 2009 10:30 pm
count me in for the most important ones on a 700/most likely to be worn to crap - i dont want to spend 900 dollars on rubber, but yea. i don't know.
halp?
im lost.
PostPosted: Mon Apr 20, 2009 11:34 pm
If they are available i'll pick them up otherwise don't worry about it. Let me know the total and i'll get you the cash.
PostPosted: Mon Apr 27, 2009 4:24 pm
Ok guys...might doesn't cut it. Need or want does. At this point I have Ian, Greg and Andy who have basically committed. I need to place my order shortly so if the "mights" actually want some, you might want to change your "might" to "want" and let me know exactly what it is you need or want...
Thanks,
PostPosted: Mon Apr 27, 2009 4:33 pm
want, essential bushing kit for my 745.
call me with price, 403 890 8324.
also, engine mounts?
