It is currently Fri Mar 20, 2026 7:44 am
 Post subject: Bov mod
PostPosted: Fri May 22, 2009 1:33 pm
So my bov has a spring that is WAYYYYYYYYY too stiff, like it barely opens at a full 10psi dump.
This is really bad for my turbo.
is there any insight on how to make a spring SOFTER?
will torching the shit out of it work? cause im sure cutting and stretching will only make it stiffer (correct me if im wrong here)
thanks guys!
 Post subject: Re: Bov mod
PostPosted: Fri May 22, 2009 1:43 pm
What BOV, and what turbo? You've got the BOV getting a signal from the intake mani, right? What engine?
I'll warn you right now, I may ride your ass about you wanting the BOV in the first place.
PostPosted: Fri May 22, 2009 2:07 pm
Awesome, we have not watched Matt riding ass for a while, this should be fun :rock:
PostPosted: Fri May 22, 2009 4:57 pm
My brother had this problem on his hks one...and i've been noticing this a bit as well on mine but only at lower boost and it doesn't open for long enough. My brothers fix for that was to remove the spring and that has been working well for him it seems.
PostPosted: Fri May 22, 2009 5:00 pm
Oh boy! an ugly duck ass ride! sign me up!! :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
Ill try taking out the spring.
oh, and its a 15g, so its easy to put the stock cbv back on. Which I may try anyways.
PostPosted: Fri May 22, 2009 7:28 pm
DOH!! #-o
the vac line was hooked up pre throttle plate...
I didn't figure this out until after I cut the spring. Now she wont stay closed at idle, so ill just shim the shit out of it, I always liked that high pitched sound anyways.
and I removed my mbc, it lost its screw so I taped it shut, aparently enough of a tape job to hold 10psi constantly. Raz would be proud of that one :lol:
besides, 5psi is nessisairy to break the new clutchnet clutch in, cause 10 was way too much.
PostPosted: Sat May 23, 2009 8:26 pm
I also have now hacked it to become adjustable. works really well now, I mean really well... sorry matt.
link
http://forums.turbobricks.com/showthrea ... ost2456195
