It is currently Fri May 01, 2026 9:43 pm
Post a new topicPost a reply Page 22 of 28   [ 407 posts ]
Go to page Previous  1 ... 19, 20, 21, 22, 23, 24, 25 ... 28  Next
PostPosted: Wed Oct 30, 2013 12:57 pm
Yoshifab has just released a conversion speedo cable for the T5 and a clutch disk. Both are on the way to me. Nice timing.
PostPosted: Wed Oct 30, 2013 10:32 pm
Excellent.
PostPosted: Thu Oct 31, 2013 10:16 am
I would have just went with one of these http://www.speedhut.com/gauges/GPS-Speedometers/1:3
A little pricey as a kit,but you can buy the speedo separately in any config you want.
Had one of these in my 760 (due to the easy way out of trying to hook up a 700r4 cable to an electronic pickup) and it worked great. Also does 0-60 and 1/4 mile. It was about $260 shipped to my door. And it doesn't care what diff ratio or tire size you have.
PostPosted: Thu Oct 31, 2013 3:29 pm
I have some Speedhut gauges for my project car...the issue isn't getting a drive to hook the transmission to the existing speedometer (that's easy) it's getting the new EFI to function properly. LH 2.4 needs a speed signal so that it idles properly and it will also cut the injectors on decel. Not a big deal, but I like it when things work properly and are not cobbled together.
PostPosted: Fri Nov 01, 2013 8:08 am
Oops..forgot about that. I can turn that off in my tune,then again I run the much better supported Ford architecture :).
PostPosted: Fri Nov 01, 2013 8:07 pm
Turns out I've got a spare flywheel. I just have to drill it for LH 2.4. No problem.
PostPosted: Wed Nov 06, 2013 7:53 pm
I took some time to break the engine down and get a good look at what I needed to do to rebuild this hulk. Let's put it on the engine stand and see what we can see.
Things are pretty disgusting…people, clean your engines.
First I pulled the plugs…oh, oh. Those electrodes on plug 1 and 2 don't look long enough and they look a little white.
Once the head was off, we see why this car was in the JY…blown head gasket.
JY guys said it was in because of a "No Start" - Ya think?
Hey, doofus, when your tail pipe is blowing white…shut off the engine. See what happened to the cylinder head. Now Junk.
Off to the JY to pull another head. Pistons on 1 and 2 were also showing signs of stress and will be replaced with first oversize parts. The rest was surprisingly in great shape. The crank and rods seemed fine (still have to measure them). 360,000 Km and the bearings looked like new.
That's all the update I have for now. Time to go clean up the parts.
PostPosted: Wed Nov 06, 2013 8:08 pm
I'm guessing the MBC I pulled off that car when it first showed up had something to do with all that destruction... On a side note what's the turbo like??
PostPosted: Wed Nov 06, 2013 9:34 pm
Good to know…the 13C is fine (needs a little cleaning).
PostPosted: Thu Nov 07, 2013 8:07 am
I'm pretty sure I've got a 530 turbo head taking up space in my garage...
PostPosted: Thu Nov 07, 2013 8:59 am
Could you check on that head for me and let me know. If not, I'll go pull one on Friday.
PostPosted: Thu Nov 07, 2013 9:38 am
I've got a 530 sitting right here taking up space. Come on over.
PostPosted: Thu Nov 07, 2013 4:12 pm
Sold. Thanks Greg.
LH 2.4 Harness arrived today…only about a dozen wires to figure out.
PostPosted: Sun Nov 10, 2013 8:18 pm
I've cleaned the 13C - the hot side is cracked…sorry Jim. So far three days of cleaning parts. Pics soon.
PostPosted: Fri Nov 15, 2013 8:00 pm
Engine's been cleaned.
90+ Manifold cracks fixed.
Post weld cool down in the oven…with my wife watching!
All the parts have been ordered.
