It is currently Thu Mar 26, 2026 7:18 pm
 Post subject: New Hahn Racecraft Super 20G and Ported R-Sport Manifold.
PostPosted: Sun Nov 08, 2015 6:08 pm
My project car is heading in a different direction and I've got some NEW parts that are no longer needed. Up for sale is my NEW Hahn Racecraft Super 20G and R-Sport exhaust manifold. The Super 20G is a brand spanking new part - ceramic coated hot-side and 7 psi wastegate actuator. Have a look at the pictures. $600 USD.
Extensively ported and polished R-Sport exhaust manifold. This manifold is prepared for ceramic coating. It's had approximately 8 hours of porting work and is polished inside and out. The ports are matched and ready to flow as fast as they can. Have a look - a bargain at $300 USD.
Get the pair for $750 USD plus shipping.
 Post subject: Re: New Hahn Racecraft Super 20G and Ported R-Sport Manifold
PostPosted: Mon Nov 09, 2015 12:37 am
Different direction eh??? Interesting....
PostPosted: Mon Nov 09, 2015 9:13 am
Hemi??? :lol:
In all seriousness make sure you post this on Swedespeed.
PostPosted: Mon Nov 09, 2015 9:22 am
So sexy, so cheap!
PostPosted: Mon Nov 09, 2015 11:51 am
I'm going to wait a bit before posting. I'm too busy to be chasing after other forum people right now. Rather see if there was someone "local" that wanted it first.
PostPosted: Mon Nov 09, 2015 4:50 pm
Greg, you need this for your XC
PostPosted: Mon Nov 09, 2015 10:32 pm
Haha! Indeed! Truth be told, I did think of the manifold. Its definitely on the upgrade list for that car....would make a massive difference. The turbo I think is a bit beyond what I'd go for in terms of size, as I kind of like how quick my current one spools.
Buuuuut....I'm hesitant because I'm still wanting a G-wagon. I'm considering this for next year. If I did, I'd sell the XC.
PostPosted: Mon Nov 09, 2015 10:39 pm
Now posted on VS (what a gong show that was). We'll see how it will go. Greg - these things spool just fine. It's not that big. Keep the XC stock, it'll be easier to sell.
PostPosted: Tue Nov 10, 2015 12:35 pm
:shock: :D [-o< =P~
PostPosted: Tue Nov 10, 2015 6:42 pm
:wink: :D
PostPosted: Wed Nov 11, 2015 8:39 pm
Price reduced - HRC have a sale on the Super 20G...so we're now at $1000 Canadian or $750 USD.
PostPosted: Fri Nov 27, 2015 3:36 pm
Damnit - Haven't been on the site for a while and just saw this... It'd suit my 2000 V70R perfectly - Damnit.
Mine 19T is in need of a rebuild and I have a flange planed R mani and a billet 19T compressor wheel I was going to do at the same time (As well as a rebuild kit). (Although - I could rebuild the 19T and sell it with my mani to offset costs...)
Craig - any idea what it would cost in addition to have the ceramic coating done on the mani? Can't quite see - but is the exhaust housing a T3 flange or is it a Volvo one? Any chance you have the downpipe flange for the exhaust housing? (Project scope escalates if the turbo needs a lot a fab to work since I also have a 3" DP for the angled compressor housing).
Thanks,
PostPosted: Sat Nov 28, 2015 11:37 am
Thanks,
Hi Rabin - I get the ceramic done in Calgary at Top Gun Coatings and it's usually under $100 if it's prepped as you see here. They just blast and coat it and with the surface finish, it's basically ready to go. I could arrange to have this done prior to shipping if you like. The exhaust is a T3, so no step machined. I hadn't decided if I wanted to machine the turbo or mill the manifold (probably mill the manifold) or just get the adapter from ATP turbo (who also have the flange). I don't have the flange - but you can get them from ATP as well in stainless (you'd have to measure) but I think their divided mitsu is the right flange. You don't need the wastegate port, so it could be just cut off (the one Hahn sells is just a 120 degree triangle three bolt, but is only 1/4" thick. Anyway, there is a reasonable and simple enough solution for fit up. Hahn and ATP and others sell the oil and water fittings that would be needed.
It's not a direct bolt in is the long and short. But I think you know that. It is probably the easiest way to hit 350 hp...this aint no puny TDO4.
PostPosted: Sat Nov 28, 2015 2:23 pm
Thanks for the info Craig.
I spent a couple hours last night researching the 20g upgrade and I'm deciding against the turbo. It's such a slippery slope into ecu tunes and injector upgrades, that even the little fab work on top makes it a bigger project. I figure I'm much better off keeping the stock 19T with some tweaks.
Would love the manifold - but exchange rate plus ceramic makes it a $500 cdn manifold which makes it a tough sell when I already have one.
Anyone else in need or an R-manifold? If I could sell my R-manifold at the same time it'd totally be doable.
PostPosted: Sun Dec 20, 2015 11:21 am
Sold.
