It is currently Sun May 03, 2026 6:38 pm
Post a new topicPost a reply Page 2 of 2   [ 29 posts ]
PostPosted: Mon May 08, 2006 9:07 pm
Seriously....what the heck? Starved for oil again eh? I'm sorry to hear this Matt.
Greg
PostPosted: Mon May 08, 2006 9:33 pm
this sucks... :cry:
PostPosted: Mon May 08, 2006 9:34 pm
No, I think it was another issue I noticed as I was putting the engine together - the crank was a bit bent, from what I don't know, and I tried straightening it but I might have messed something else up worse by doing it. I think it might have been bent and not fixed by the machine shop, 'cause I've always had main and thrust bearing troubles.
This spare engine is BEAUTIFUL. I've got it all apart and it's frickin' gorgeous.
Should be on the road again in a week or so. No worries! 8)
PostPosted: Mon May 08, 2006 9:38 pm
you see when you say that i believe it!
when i say it's 3 weeks down the road... :oops:
call if you need an apprentice... :wink:
PostPosted: Mon May 08, 2006 10:16 pm
Excellent! Are you swapping heads from the bad engine?
Greg
PostPosted: Mon May 08, 2006 10:31 pm
Hey Ian...you wouldn't happen to have a few free hours to give me a hand with some brake line bending and flaring etc, would you? Got the brakes all worked out, just need some lines to make them work... :P
As long as I get my car finished off I should be able to donate a few hours on Sunday, does that work?
PostPosted: Tue May 09, 2006 6:59 am
Greg
Everything but the block, crank, rods/pistons/rings, and oil pump will be coming from the other engine.
PostPosted: Tue May 09, 2006 7:20 am
I feel for you Matt
May the clean oil gods smile on you and keep everything lubricated and running smoothly [-o<
PostPosted: Tue May 09, 2006 7:38 am
Thanks Ian - sorry to jack your thread.
PostPosted: Tue May 09, 2006 7:53 am
:butthead:
PostPosted: Tue May 09, 2006 8:41 pm
quoting for the second time in the same thread...ftw
after that may we take a look at the true trac???
[-o<
if you have time
PostPosted: Tue May 09, 2006 10:23 pm
Can we do it after the dyno day?
PostPosted: Tue May 09, 2006 10:45 pm
oh hell yes...just hoping before the lethbridge show...so mid july, then there is no "rushing" before the BC trip...you know? i wish all of our vehicles to need a couple fluid checks before BC and thats it
hopefully!
PostPosted: Sat May 27, 2006 7:50 pm
Ian, I received my package on friday...well half of it, you are welcome to come by and pick up two springs to try out if you want.
